Hey dude,
I have been looking into this unit myself and it seems to be a very decent piece of kit, at a very attractive price point too!
They have released plug-in versions for popular cars such as 'S' series nissans, R33's, WRX's etc. These are a full replacement ECU that can be tuned by a optional hand controller or laptop with appropriate software. The good thing about having the hand controller is that it can display all sorts of info about the car.
Check out www.wolfems.com.au for more.
Mat
https://www.sau.com.au/forums/topic/5285-wolf-3d-v4-ecu/#findComment-81159
Originally posted by GOT BOOST
i had wolfs on 3 of my rotary cars 2d 3d V2 & V3 and helped my friends with his new 3d version 4. i dont like the version 4 and speaking to a few people they are not overly impressed either. formaz sold wolf now they are pushing Haltech.
An explaination of why you dont like it (version 4, not 3.) would be appreciated. :D
https://www.sau.com.au/forums/topic/5285-wolf-3d-v4-ecu/#findComment-81290
Nothing against Formaz Got Boost, but their name since changing ownership has not been the best.
I would be interested in seeing why they do not like the V4...more tuning resolution, faster processor etc, surely that would make it a better product. Maybe they don't like the laptop interface???
https://www.sau.com.au/forums/topic/5285-wolf-3d-v4-ecu/#findComment-81496
Mat
I am definitely going for the Wolf V4 plug & play for the R32 GTR.
As you know, I got to know the PFC very well on my old S15. The unit has some great pros, however one of the biggest cons was that there is no temperature correction.
Detonation was much more evident during the summer months and during the day. As you only have the choice of only one set of "custom" maps or the factory (default) maps, this means that you either run a conservative map in the cold weather, or have to spend a fair bit of time remapping for summer/daytime performance runs.
The PFC also uses MAF (airflowmeter) rather than MAP. This is not really a problem in terms of flow restrictions as you can bolt on a big Z32 meter (or a pair of the suckers for an RB26). Don't know which option I will use for the GTR as I have heard that the 6 throttle bodies don't give a stable MAP reading.
https://www.sau.com.au/forums/topic/5285-wolf-3d-v4-ecu/#findComment-82271
Yep - he knows his Wolf systems pretty well and is bloody patient when it comes to ironing out "gremlins" when tuning.
Guess I'm biased towards Grant/Steve after the huge effort that they put in on the S15 and they didn't even supply the ECU.
There should be a few Version 4 installations running around now and I will be speaking to some of the guys that have gone this route.
BTW - Jash has landed that blue V-Spec. Drop by there and give me a first hand report if you are ever in the area.....
https://www.sau.com.au/forums/topic/5285-wolf-3d-v4-ecu/#findComment-82990
Originally posted by Gav
Mat
PFC does have temp correction (Lamda) BTW.
https://www.sau.com.au/forums/topic/5285-wolf-3d-v4-ecu/#findComment-83696
I'm not sure what you're referring to.
PFC generally uses only the existing sensors. On the SR20 motors there is no measure of air intake temp, therefore the PFC cannot correct for this. I don't think the RB motors have this either.
Lamda refers to the stoichiometric air/fuel ratio of 14.7 and is not directly related to temp correction. The PFC does use the O2 meter for closed loop (cruise) mode.
https://www.sau.com.au/forums/topic/5285-wolf-3d-v4-ecu/#findComment-83798
Sorry gav I meant temp compensation lamda as in this comparison:
http://www.users.bigpond.net.au/r33/ecu.jpg
https://www.sau.com.au/forums/topic/5285-wolf-3d-v4-ecu/#findComment-83941
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
