My 1st post here... Here goes :D
I know we are all pro skyline but i love my commodore too much to sell it... So I figured give it the best brand of heart available :D
I picked up an rb20 for a good price so going to be using that...
Just a few q's tho...
1) what gearbox's can I use? I want to keep it manual.... Also with the gearbox choice what gearbox crossmember can I use?
2) I have the vk manual pedalbox in there atm which is used for cable style clutch. Any way I can convert this to hydraulic style clutch or do I need to go for a vl pedalbox?
3) With the above gearbox choices can I use a vl tailshaft? I have a borg warner diff
4) Diff will be a lsd/spool borg warner with 4.11 diff gears... Is this enough?
5) I currnetly have a vn steering rack in there can I adapt this to the rb20 or do I need a vl rack?
6) Fuel pump. I have a vn fuel tank with unleaded filler restrictor on there with a vn v6 fuel pump and malpassi fuel reg. Is this pump enough or do I need an rb30 item? Or even aftermarket surge tank?
7) cooling wise. I have a vn radiator in there atm this will be fine to use with the clutch fan?
I think thats all I can think of atm although there will be more!
Basically it has all the right incrediaents for fun... rwd + turbo + manual + 6cyl :P
Thanks for your time
https://www.sau.com.au/forums/topic/52860-rb20det-into-a-early-model-commodore/
Hey man,
1) u should be able to use the 5 spd out of a VL .. and crossmember mount...its pretty much teh same gearbox as an RB20DET box .....dont quote me that .. just what i;ve heard.
2) yea go the VL pedal box. for ease of it anyways
3) Yes
4) Should be plenty. bare it mind you may still have get down to a Gauge expert and have a speedo box calibrated and fitted to suit your application.
5) i'm pretty sure the racks are the same ... but it should be fine anyways.. u might have to fiddle with the brackets for the pumps .. just keep an eye on the pulley ratio coz u dont wanna end up boiling your steering oil and killing the pump from the working its tits off.
6) Fuel pump should be alright. u wont need a surge tank for street use.
7) u should be able to hook up a thermo fan into the wiring on the rb20 donk .... something like a davies craig deal ..and fittings to suit. or a switch to turn it on when its copping some stick
All the best.
VK with a Rb20 det ...... interesting concept..... u should just go with a garret Strata kit for turbo power on a 6cyl .. unless u got a v8 one
Matt
Ive done this conversion it was about 3 years ago for a close mates brother though so its not real fresh in the memmory Ill try to jog it
http://www.antilag.com/projects/mayhem/odds/vkrb20.JPG
http://www.antilag.com/projects/mayhem/odds/p8.JPG
http://www.antilag.com/projects/mayhem/odds/RBVK2.JPG
use the vl engine crossmemeber and steering rack, you convert over to the hydrualic clutch setup with rb20det box now the box crossmember i recall was modified vk
4.11s is top call this one was still 3.23 and stayed that way till it was sold, way way too tall really hampered acceleration at low rpm.
the vn rad is hooooooge compared to a lil r32 item so it should be more than adequate
Tailshaft was a modified vl -> vk one
your fuel pump....... old pumps not really ideal Id probbaly invest in a new walbro if you can afford one $220 new and rated at 450hp
This one ran a GT 25 bb turbo full exhaust cooler but she never saw her full potential as she was sold off before it was fighting fit. Hope you see yours through to the end.
Definately get the 4.11 gears.
If you can stretch a little more to say 4.363:1 like the R32's stock setup do it.
The RB20DET really needs 4000rpm+ on board to haul arse..
Under that and it feels a little sluggy under hard acceleration.
This is why you need a decent diff ratio. :(
Remember the RB20DET has no problems flicking over to 8000rpm once it has a decent turbo hanging off the side.
With the stocker turbo running 16psi with no boost drop off I rev mine to around 7300rpm. It appears to be the sweet spot.
When boost used to drop off a little I found reving over 7000rpm to be usless. It felt like power would drop off.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
