Basically the GTR Sumps where designed badly for race track use, it relates to the placement of the front differential.
On a race track, the costant excessive cornering, can (and usually this is just a matter of time) cause oil starvation on an unbaffled GTR engine. Basically the oil in the sump sloshes around, and for some time period, there is a HUGE danger that the oil pickup will not pickup any oil.. this combined with the usually high RPM's, causes instant death to your engine.. (and a $6k+ rebuild :)) remember, @6000rpm, that equals 100rpm's per second, just 2 seconds of lack of oil can mean 200 revolutions of no lubrication :(
i am not being alarmist either, it seems to be the case that if you run an unbaffled GTR on the track, you are playing russian roulette, some GTR's can blow on the 1st or 2nd lap (usually when you start taking the corners with gusto :P) or you may get through unharmed (but it always seems to be a matter of time!)
basically the only proper solution is to install a oil sump baffle, in combonation with a tomei oil restrictor to the oil gallery in the head, to ensure proper oil flow..
do a search here on SAU for GTR and sump Baffle.. you will read many many horror stories...
scary stuff!
People seem to think that just because the GTR is an awesome road car, it was built specifically to race on the track, this is not the case!
Very interesting, i have had a similar problem in the past with a mini..
When my car arrives (5 or 6 weeks) i will need to see if this modification has already been done, if not i will definitely be buying some form of sump baffle.
so a Tomei restrictor restricts oil going up to the head? does the head get too much oil normally or something like that?
-Patrick
yep, it is a little pill that you fit into the oil gallery on the block (you have to take the head off), this reduces the oil by about a 1/4 (1.5mm from 2mm)
http://www.tomei-p.co.jp/_2003web-catalogu...l-lub_rset.html
    • Interesting, I've heard complete opposite on my end. Bit of a lottery I guess.
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
