Engine mount on the left side broke but lucky i had the r34 strutt so that gave the engine bay extra strengh otherwise the impact would have damage the engine.
About the compliance plate, i'll need to call up Canberra see if am i in anykind of trouble if i give it away with the wreck.
Forgot to add i have exceedy button clutch in the box as well so there go here is another bonus.
I really want to take it to ice to have it strip down and make more $$$ but it seem like ice is just too busy so any inspec wont' be at ice until NIGEL is ready. Well it doesn't look like it will make it to ICE as i HAVE a few GENUINE offers.
Test drive an EVO1 today and the power out put is not even near my cars' out put, i really like to see it on a silvia and see what it does.
How much for the fuel pump?
Sorry don't know yet, it could be an after market item as it make noise as hell or could be faulty :P .
Anyway to everyone else......Shane, Ash, Scotty.......car will be tow to ICE this friday arvo cos' last deal didn't fall through due to financial problem.
:headshot:
Strip it yourself, why do you need a workshop to do it.
Is the gearbox for sale or is it part of then engine package or are you still looking at the whole car only?
Well once it's at Ice which this friday, first in best dress. strip it myself? guess i could but i don't have space as i'm boarding off ppl and i just don't have the time .
A guy just call me up from Sydney reckon dealer charge him $7k just for a haft cut alone and my come with ----> refer to pic so $6k still a bloody good bargin.
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
