Guest darrinspencer Posted October 7, 2004 Share Posted October 7, 2004 I am looking into the "posibility" of fitting Toyota Supra IV twin turbo USA spec 550cc injectors into a RB25det. Japanese spec are 480cc. The injectors are low impedence, but RB25 use high impendence Is there some way of re-wiring etc to get these to work? Will they fit into the fuel rail with little to no mods? I have a new Wolf plug-in ecu, which is not fitted yet, will this be able to run low impedence injectors instead of high impedence? These injectors can be found for about $150 aust., hense the consideration in finding out if these will work Has anyone tried these? Attached is a photo of what they look like the blue set of six Also attached is a photo of nismo 555cc injectors, just to compare Link to comment https://www.sau.com.au/forums/topic/52938-fitting-550cc-supra-2jz-turbo-injectors-into-a-rb25det/ Share on other sites More sharing options...
Chris32 Posted October 7, 2004 Share Posted October 7, 2004 Dunno if they would fit, they look alot like RB25 injectors though If they are low impedence, you could wire in a GTR resistor pack and it should work fine Chris Link to comment https://www.sau.com.au/forums/topic/52938-fitting-550cc-supra-2jz-turbo-injectors-into-a-rb25det/#findComment-1040206 Share on other sites More sharing options...
MonstaS4 Posted October 7, 2004 Share Posted October 7, 2004 They look too large at the base to fit in the RB25 rail. Have you looked into 550cc 20B cosmo injectors? Link to comment https://www.sau.com.au/forums/topic/52938-fitting-550cc-supra-2jz-turbo-injectors-into-a-rb25det/#findComment-1040378 Share on other sites More sharing options...
Guest darrinspencer Posted October 7, 2004 Share Posted October 7, 2004 They look too large at the base to fit in the RB25 rail. Have you looked into 550cc 20B cosmo injectors? I have, but they are hard to get and are nearly as dear as buying s/hand Sard etc rb25 injectors, also the WRX boys want them Link to comment https://www.sau.com.au/forums/topic/52938-fitting-550cc-supra-2jz-turbo-injectors-into-a-rb25det/#findComment-1040388 Share on other sites More sharing options...
DoughBoy Posted October 7, 2004 Share Posted October 7, 2004 $900 for a set of 6? You can get the correct ones from Nengun or Greenline for that amount. Link to comment https://www.sau.com.au/forums/topic/52938-fitting-550cc-supra-2jz-turbo-injectors-into-a-rb25det/#findComment-1040507 Share on other sites More sharing options...
MonstaS4 Posted October 8, 2004 Share Posted October 8, 2004 Try Dyson rotary. I picked 3 up from him and 3 from a guy on the Ausrotary forum. Link to comment https://www.sau.com.au/forums/topic/52938-fitting-550cc-supra-2jz-turbo-injectors-into-a-rb25det/#findComment-1042484 Share on other sites More sharing options...
N I B Posted October 8, 2004 Share Posted October 8, 2004 Yes they will fit with a little effort and the wolf Plug in will drive them with no problem with out any need for a resitor. If you have any doubts email Wolf in Australia and say Steve thomas from SST told you the wolf will drive these injectors. Link to comment https://www.sau.com.au/forums/topic/52938-fitting-550cc-supra-2jz-turbo-injectors-into-a-rb25det/#findComment-1042581 Share on other sites More sharing options...
Guest darrinspencer Posted October 10, 2004 Share Posted October 10, 2004 Try Dyson rotary. I picked 3 up from him and 3 from a guy on the Ausrotary forum. So are you using these in a RB25det? If you are, what was needed to make these work. Steve- thanks for the answer. Link to comment https://www.sau.com.au/forums/topic/52938-fitting-550cc-supra-2jz-turbo-injectors-into-a-rb25det/#findComment-1044869 Share on other sites More sharing options...
KamikazeR33 Posted October 10, 2004 Share Posted October 10, 2004 steve do u know if a microtech would work the same way as the wolf would in this scenario i have a set of 600cc nismo gtr injectors to go in with hks fuel rail btw. Link to comment https://www.sau.com.au/forums/topic/52938-fitting-550cc-supra-2jz-turbo-injectors-into-a-rb25det/#findComment-1044888 Share on other sites More sharing options...
N I B Posted October 11, 2004 Share Posted October 11, 2004 Ask Microtech if they can use low impedance injectors but i think they can. Link to comment https://www.sau.com.au/forums/topic/52938-fitting-550cc-supra-2jz-turbo-injectors-into-a-rb25det/#findComment-1044958 Share on other sites More sharing options...
MonstaS4 Posted October 11, 2004 Share Posted October 11, 2004 So are you using these in a RB25det?If you are, what was needed to make these work. Steve- thanks for the answer. I'm using these in an RB30DET with the R33 head. I machined up some aluminum collars to locate them centrally in the bowl. A small amount of material needs to be removed from the bottom filter cage and aluminium tip so they will fit into the bottom of the bowl. Plugs are different. Rather than "cut and shut", i bought new terminals and plugs and re-crimped them. They are high impedance (13 ohms i think). Link to comment https://www.sau.com.au/forums/topic/52938-fitting-550cc-supra-2jz-turbo-injectors-into-a-rb25det/#findComment-1045096 Share on other sites More sharing options...
Guest darrinspencer Posted October 11, 2004 Share Posted October 11, 2004 I'm using these in an RB30DET with the R33 head. I machined up some aluminum collars to locate them centrally in the bowl. A small amount of material needs to be removed from the bottom filter cage and aluminium tip so they will fit into the bottom of the bowl. Plugs are different. Rather than "cut and shut", i bought new terminals and plugs and re-crimped them.They are high impedance (13 ohms i think). The US spec are low impedance. What computer are you running? Link to comment https://www.sau.com.au/forums/topic/52938-fitting-550cc-supra-2jz-turbo-injectors-into-a-rb25det/#findComment-1045151 Share on other sites More sharing options...
MonstaS4 Posted October 11, 2004 Share Posted October 11, 2004 I think we have a communication breakdown here..... To clarify, I have 20B cosmo injectors which i sourced from dysons and a rotary forum. These are high impedance. I machined up collars to fit these in the r33 rail as i mentioned above. Computer is Haltech E11. Link to comment https://www.sau.com.au/forums/topic/52938-fitting-550cc-supra-2jz-turbo-injectors-into-a-rb25det/#findComment-1045801 Share on other sites More sharing options...
