hi,
it is actually going into a friends 200sx, though i can't imagine it would be too dissimilar.
looking to work out how to connect it, both electrically and vaccum wise.. i had heard that the US greddy instructions where wrong..
thanks guys! appreciate the very quick response!
hey Y0880,
electrically, was the hardest i wasnt to sure were to connect it so basicly, i chop the wire which goes from my fuse box to my cd deck, made a connection for the power wirer (cant remember wat colour, but im pretty sure red is power, black is ground) then i also add a fuse just incase it got too much power, i can take photos of what the wirer etc look like if u like?
that would be fantastic,
i will double check the wiring loom but i though there was around 6 or so wires.. i will get the colours and post them up, if anyone can match them it would be appreciated, hoping to get it in tommorow afternoon :rolleyes:
Okay, this is a little hard to explain, so i drew a crappy picture
white = ?
brown = ?
Then there are the two wires that obviously are
red = Power (Acc?)
black = Negative
any help on the white and brown would be great, as would the photos of the stepper motor and it's connections
i will get an actual photo posted very soon
white = ?
brown = ?
red = Power (Acc?)
black = Negative
Ok, I am the "friend" who is getting the profec fitted to my car.
Here are some photos of the cabling of the unit.
dscn0391.jpg - shows the complete wiring diagram so you have an idea how it all connects
dscn0396.jpg - shows the unknown red and black cables
dscn0401.jpg - shows the unknown brown and white cables
Appreciate any help anyone is giving.
Ok, i took some photo. Hope this helps
basic,
the red one (right) goes to the stock wastegate (i think that its called :D)
the blue one (middle) goes onto the pipe whichs goes from the plenum into the intercooler and has the bov on it
the black one (left) goes where ur boost gauge is
now for the wirering part, i am unsure wat the brown and white wirer do maybe they have been cut not sure, as mine had only the red and black
Black is ground
Red is power
Tip for install it; try to add longer wirers onto the ground and power as mine where short
i have attach an image of wat mine looked like when i 1st got it (the wire part)
thanks Michael,
much appreciated, it will all make things go smoothly i am sure!!
hmm bizzare, there are 8 wires going into the connector (all accounted for), then the two wires.. yet the cables don't come out the other end..
i guess they arn't used then, will give that a go..
Thanks
Kent
basic,
One last question mate. There is one single outlet for another tube coming out of the other side of the actuator from the 3 other tubes (seen at the very bottom of your pic you posted 13_Devil. (same side as the wiring outlet)
Would you please be able to trace where this tube goes to for me please ? We would like to fit the controller today so any help is appreciated.
Thanks
Dean.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
