SAUWA is planning on holding another Dyno Competition, so get your cars ready and come down to SST on Sunday 17th of October.
SST have moved workshops recently, and are now located at Unit1/25 Forward St, Victoria Park.
We'll kick things off about 11am, and will stop for a BBQ lunch at mid-day before continuing with more cars:D
Cost will be $30, and will provide you with a power reading, which is cheaper than you would get on any normal day, so it's a great opportunity to see what your car is doing:D
Please register your interest in this thread so we can determine who is coming:D
We'll have trophies for the category winners.
Don't feel that you need to have a huge horsepower car to enter, it's a fun social event, so make sure you all come down.
Cheers
Paul
SAUWA President
https://www.sau.com.au/forums/topic/53027-sauwa-dyno-comp-oct-17th/
  • Replies 103
well these gear boxs have a lever on them which you can pull out to lock the diff, which would make all the power go to the front wheels, but you have to dissconect the drive shaft anyways. i could do that, but i cant be stuffed.
thanx anyways, ill wait till my gtr arrives.
steve
count me in Paulie!
want tosee what the thing doesbefore i put the cooler on.
I may be a little late as i have church in the morning until about 12 so i will come after the BBQ.
Let me know if that is cool.
And Avram... i expect to see you there too... would be nice to finally catch up and say hi after all those years.
God Bless,
Nate
