  • Replies 103
Cool - Aiming for about 270-280hp on Stock turbs! You guys better stand back, I will overboost it if I have to (good excuse for a new turbs)
kym..remove your Cat then, so someones head catches the piece of turbine instead of your exhaust :P
damn i wish i could come. got paint balling on this sunday maybe it might be finished by lunch but i dont think so. Would love to bring my car down and see what she does as she is completly stock at the moment
will there be another dyno day?
I might make the trip over to SST to watch but not to participate. My beast isn't going on again until the PFC is tuned. Last reliable measure was 314rwhp @ 14psi so i'll get the PFC in and blow you all away (well some of you) at a later date. ;)
