  • Replies 103
man, even with my busted fuel pump bam, I'd beat you :D
Hey Jas what exactly happened with your pump man?
I was on the rollers just before and after you (as you had to get fuel)
and all i saw was a you get on, do one run and then get off... what happened dude? is she alright?
I was going to come over and intruduce myself, but you looked busy at the time.
Best of luck pal,
God Bless,
Nate
Hey Nate,
My fuel pump, she went BOOM.
Thankfully it's been picked up now and hopefully there isn't too much damage.
Just organising replacing it at the moment. Unfortunately it's now eaten in to my safc2 budget, but whatever will be, will be (I'd have said it in French, but I've got no idea how!).
Next time just throw something at me, that'll get my attention!
Thanks for asking :(
Jason.
And hes even added it to his sig already!
Jason you went very quite when that happened huh! Fair enough...
Jason nearly 3 years ago when i got SLY i just started out with a SAFC and dump pipe and air pod.... 3 years later and $20,000 in extras including a fuel pump it wouldn't surprise me if you would need one further down the track anyhow...
it's starts off with an SAFC and finishes with Engine Rebuild, hi flow turbo Wolf 3d Ex Cam Gears.. thats just the tip of the ice burg..... included in that though is a FUEL PUMP..... my main point and what i said yesterday you will need one anyway later down the track..... especially when ya car starts makin 300+rwhp... and yes one day it will be making that much!!!
awww i missed Nate :( Was there til about 1:30 .... didnt put Niz on - if there's anything wrong with her i personally prefer to live in denial about it at the moment ;)
Sooooooooooooory Loz :(
I would have just missed you... i did see something black blur through one of the side streets just off Albany Hwy on my way there though... tisk tisk Niz :)
And Avram... sorry aging dude... we will meet again mwhahahaha :elaugh:
I had church which dragged out a tadbit longer than anticipated :(
Although Loz, you wil be happy to know that now i know what my car is pulling...i want MORE POWER (in a big booming voice) and the cooler is definately on the books for this christmas holidays... and if your lucky...and nice to me... i will do your piping for your cooler too ;)
Will see you on the cruise though.
God Bless,
Nate
ahh yes that wouldve been me :( Went for a beer with some mates after at Cheers then headed down for a bit of a solo coastal cruise :(
I want more power too :elaugh: although probably get me in more trouble with the law :(
Thanks Paul - beginning to think that it's never gonna happen!
Give Ant a kick in the pants (sounds like a nursery rhyme doesn't it) for me and forget about all the "prettying up" of the engine bay - he's got 4 weeks left to get it all back together and run in!
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
