yeah 18s will fit fine... just make sure the offset is right.
the one im selling has 18x10s on the rear with 235s stretched over them :D and they have a huge spacer on em.
but of course the guards are rolled and the wheels have neg camber so that helps i spose :) altho without the spacers they might fit anyway.
If you want to adjust you neg camber to accomodate some bigger wheels I have organised a group buy of Adjustable Rear Upper Links for $225 for a set. Im putting some on my car so I can eventually have white powder coated R33 GTR wheels in nice n tight :D ooo yeah baby...
JK
+40 offset is fine dude, that's more like FF car offsets. remember people, the smaller the number is for the offset, the more the rim sticks out. so very few cars can have 0 offset without flares. only thing is +40mm offset wont clear bigger brake calipers, but at least you can have a 8 or 9 inch wheel under standard guards...try go for +35 or less for 8 inch wheels to give that flush look :D
  • 2 years later...
Sorry to resurrect this thread,
but I'm once again buying new rims...
I won't say what, all I'll say is this...
Dual PCD : 4x114.3 & 5x114.3
Front : 225/40/18 18x8J, offset 23
Rear : 245/35/18 18x9J, offset 35
Obviously the PCD is correct, (duh)
the rears are fine I'm sure, but I do query the fronts, 8" wide and 23 offset? can anyone tell me how that would turn out?
...so I won't catch superAIDS if I put 8inch wide +23 offset? with stock front guards? they are slightly lipped though, by saying lipped i mean i have tucked the lip up on the inside of the guard...
...I'm excited about this, are you?
My Cefiro has 17x8 with 225 on the front and 265 on the rear. I think the offset is +41 [but I may be wrong... it's been a while since I got them and I'm not entirely sure]. I'm running R33 brakes all around and have loads of clearance without resorting to using spacers.
The fronts sit nicely in the guard and no clearance issues. The rears do stick out quick a lot... I have adjustable camber kit on the back and am running quite a lot of camber on there, and even so the wheels do stick out about half an inch at the top. I had to lift up the coilovers to nearly maximum height to give enough clearance and stop scuffing when the car bottoms out.
Will post a pic up soon as I get my car back from the autoelectrician...
