Hey people,
Well this is really starting to pi$$ me off. There is a hissing sound (sounds like an air leak of some description), coming from the drivers side footwell, right near the pedals.
It will hiss whilst in vacumm and the hissing goes away once the car starts to make some boost. Also, the sound goes away when the clutch pedal is pushed in about half a centimeter (not actually engaging the clutch).
I have checked the hoses for the boost gauge in the car as well as the boost controller and the lines are perfectly fine.
I'm stumped as to what it may be.
Anyone had any similar problems?
Cheers
https://www.sau.com.au/forums/topic/53063-worth-a-tryreally-odd-hissing-noise/
I got the same problem on the drive from canberra up to brisbane. I have been told its more likly to be the diafram in the clutch booster or something. I am not a mechanic.. But if you feel the rubber behind the clutch you should be able to feel it "breathe" as i like to call it, I am waiting till i get back to canberra as i have been assured from my mechanic it will be ok, Just the clutch is heavier...
Good luck, If you hear any different, Please let me know, Second and third opinions never hurt.
Cheers
Try blocking/clamping the vacuum hose to the clutch booster,if the hiss stops its the booster.
Then unbolt the clutch master cylinder and check the rear seal for leaks/fluid.
A leaking rear seal will let brake fluid get sucked into the booster and ruin the booster seals and give a vacuum leak. Both the booster and master cylinder will
require overhauling.
flushing the clutch and brake fluid every 2 years will stop this from happening.
hope this helps. :how:
Didnt think there was such thing as a clutch booster. If your talking about the brake booster then yes definately. another thing is, if your brake booster fills with brake fluid, this will get sucked into your motor through that vacuum hose and hydro lock your engine.
This is not good, its happened to me, totally destroyed a brand new engine. Brake fluid does not agree with engine parts !
In the end it was the Clutch Booster. I think that only the GTRs have the sort of "hydraulic" set up when compared to GTSts and the like. The booster is being replaced on Thursday so I'll post up if this has fixed it or not.
Thanks everyone for their help!
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
