Locked Diff, ActiveLSD, or LSD ? Someone explain...
Hi guys,
I've seen some skylines around with what I assume to be "Locked Diffs" they make this skipping noise of the inside wheel while turning tight corners.....
... first of all, is this safe for daily driving ?
Does anyone here recommend a locked diff brand/type ? Are there switchable diffs to lock/unlock them ?
What's wrong with the standard LSD that comes with Skylines ? Or was it an option?
And what exactly is an active LSD ?
Are you able to lock a standard skyline diff ?
I have Active LSD on my R33 SII GTS-25T and this is what I know about it and it aint much.
The Active-LSD uses a computer to sense wheel slipage and diverts power to the aposing wheel rather than by mechanical methods, the main difference is the speed that is can tranfer power from wheel to wheel. 1/50 sec. It uses a similar system to the 4WD system on the GTR but only transfers power from side to side.
I've got a mechanical in mine and your right, they are a bit noisey around tight slow corners. But apparently they give you the best grip for a (two wheel drive) rwd car.
Straight line drags are great, corners are a bit strange at first, but once you realise that they are very pradictable your OK.
They really aren't as bad as everyone says they are in the wet either.
J
Originally posted by tlai909
Do all Skyline r33 models have the basic mechanical LSD?
T.
All turbo R33's have LSD as standard. But mechanical locking LSD's are an after market thing.
Some loucky people got the Active LSD's, they are again different to normal LSD and mechanical locking LSD's.
Sooooooo many diff's.........
J
  • 6 months later...
Guest neoGT-25
whats the best diff for a car like mine to get it drifting? (Slow & Heavy)
I want to convert my car into a drifter ;) anyhelps appreciated
I'm looking at getting a manual r33 sedan still deciding on turbo or not.
so does that mean a turbo sedan will have a viscous LSD and a non turbo wont have LSD?
can someone clear it up for me please.
whats there to decide? get the turbo!! You prob wont even need LSD in a non turbo most of the time ;)
-is the std diff in the turbos viscous? or does it have clutch plates? what is a viscous LSD?!
Yeah, standard diff is viscous.
Viscous diff uses property of the oil to limit slip - as slip occurs it get stickier. quickly.
The active diffs use sensors on the wheels, and electronically controlled clutches to control torque - just like the front to rear split in atessa.
with the mechanical... so it locks under power ?
That sounds good... The wet wouldn't bother me as my car is nasty as it is so i take it easy.
But it can be a little unpredicatble at times, so J, if as you said it makes it more predictable ?? Then i would want that.
And that's good for drifiting isn't it ? That's what i'm aiming for over the next 2-3 years as a project!
R31 - yepp, you've hit the nail on the head. From my limited experience (cause I drive like a granpa most the time!), when the back comes around it's very predictable.
From what I've read, the mechanicals are great for drags and trackwork, and even better for drift. They can be a bit noisey for street driving. Some days it pi$$es me off, but other days I think 'damn I love this diff !!'
Like last night overtaking someone doing 70 in a 80 zone... Raining... I drop it back to 3rd and give it 1/2 throttle. It starts spinning the wheels but it still holds a dead straight line.... Unless you flick the wheel a bit of course :)
doesnt a locked diff mean that both wheels are forced to spin together at the same speed regardless? which would be uterly useless for track work not to mention day to day driving, youd be wheel spinning around corners wouldnt u? im prolly hopelessly wrong thou
Meg's - does your's clunk (inside wheel skip) around tight corners when you give it a bit of throttle?
GaryD - Mechanicals only lock up when the throttle is pressed, so they are sort of open wheeler diffs until you give it some go.
The reason why they are good for track work is cause instead of pulling hard out of corner from just before the apex and spinning the inside wheel (typical for even LSD diffs) they will power around with both wheels with a bit of oversteer.
But the oversteer isn't massive and is very easily controlled. Infact most, if not all V8 supercars use either locked or mechanical lockers of some sort.
I was up at Wakefield last friday watching the Brute Utes have a pratice, and as they were coming into the workshop area all of them were skipping the inside wheel while turning tight and slow....
J
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
