Hi guys,
I've seen some skylines around with what I assume to be "Locked Diffs" they make this skipping noise of the inside wheel while turning tight corners.....
... first of all, is this safe for daily driving ?
Does anyone here recommend a locked diff brand/type ? Are there switchable diffs to lock/unlock them ?
What's wrong with the standard LSD that comes with Skylines ? Or was it an option?
And what exactly is an active LSD ?
Are you able to lock a standard skyline diff ?
I have Active LSD on my R33 SII GTS-25T and this is what I know about it and it aint much.
The Active-LSD uses a computer to sense wheel slipage and diverts power to the aposing wheel rather than by mechanical methods, the main difference is the speed that is can tranfer power from wheel to wheel. 1/50 sec. It uses a similar system to the 4WD system on the GTR but only transfers power from side to side.
I've got a mechanical in mine and your right, they are a bit noisey around tight slow corners. But apparently they give you the best grip for a (two wheel drive) rwd car.
Straight line drags are great, corners are a bit strange at first, but once you realise that they are very pradictable your OK.
They really aren't as bad as everyone says they are in the wet either.
J
Originally posted by tlai909
Do all Skyline r33 models have the basic mechanical LSD?
T.
All turbo R33's have LSD as standard. But mechanical locking LSD's are an after market thing.
Some loucky people got the Active LSD's, they are again different to normal LSD and mechanical locking LSD's.
Sooooooo many diff's.........
J
  • 6 months later...
I'm looking at getting a manual r33 sedan still deciding on turbo or not.
so does that mean a turbo sedan will have a viscous LSD and a non turbo wont have LSD?
can someone clear it up for me please.
Yeah, standard diff is viscous.
Viscous diff uses property of the oil to limit slip - as slip occurs it get stickier. quickly.
The active diffs use sensors on the wheels, and electronically controlled clutches to control torque - just like the front to rear split in atessa.
with the mechanical... so it locks under power ?
That sounds good... The wet wouldn't bother me as my car is nasty as it is so i take it easy.
But it can be a little unpredicatble at times, so J, if as you said it makes it more predictable ?? Then i would want that.
And that's good for drifiting isn't it ? That's what i'm aiming for over the next 2-3 years as a project!
R31 - yepp, you've hit the nail on the head. From my limited experience (cause I drive like a granpa most the time!), when the back comes around it's very predictable.
From what I've read, the mechanicals are great for drags and trackwork, and even better for drift. They can be a bit noisey for street driving. Some days it pi$$es me off, but other days I think 'damn I love this diff !!'
Like last night overtaking someone doing 70 in a 80 zone... Raining... I drop it back to 3rd and give it 1/2 throttle. It starts spinning the wheels but it still holds a dead straight line.... Unless you flick the wheel a bit of course :)
Meg's - does your's clunk (inside wheel skip) around tight corners when you give it a bit of throttle?
GaryD - Mechanicals only lock up when the throttle is pressed, so they are sort of open wheeler diffs until you give it some go.
The reason why they are good for track work is cause instead of pulling hard out of corner from just before the apex and spinning the inside wheel (typical for even LSD diffs) they will power around with both wheels with a bit of oversteer.
But the oversteer isn't massive and is very easily controlled. Infact most, if not all V8 supercars use either locked or mechanical lockers of some sort.
I was up at Wakefield last friday watching the Brute Utes have a pratice, and as they were coming into the workshop area all of them were skipping the inside wheel while turning tight and slow....
J
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
