Ahhh cool,
That's one thing I was going to post a thread about "which oil to use for a mechanical diff".
Do you know which oils to use? Appart from the fact that I should change it cause the gearbox was never changed, so i should do the diff too. Plus I wouldn't mind loosening it up a little.
J
  • 6 years later...
hi to all in this trend ive got a 94 r33 gts ive big plans for it at the mo the first thing ill be looking at is the suspension and work my way threw i guess the biggest thought on my mind is that my 33 is currently only free wheeling rear end ive heard from a few of the drifters round the way is you can lock a standard diff by welding your standard diff internals is this something any of you guys have attempted theyve spoken highly of this mod saying you dont get veriation from the switchn while drifting also i have noticed after they when turning in tight spots their rears do skipp massively and the cars tend to push foward rather than turn in cant be good for your day to day use or runnin to the super market also alot of 3 point turning so yeh is there such thing as the best of two worlds i wonder?????
I was told i had a locked Nismo diff of some sort, and in regards to wet weather, it is pretty bad, as when u hammer the pedal the rear end just spikes out, i found out the hard way doing a 360 around a round about, and thats with 4wd. =(
News flash, you have a powerful RWD car.. :P
I have the standard viscous diff and I have had one or two big "oh shit" moments when the rear stepped out on me. The only thing that'll save you in that situation is a diff that's completely open and single spins. Soon as both wheels are spinning you're going to get oversteer.
A locked diff will definitely step out, but they are predictable in the sense that you know they will *always* make you go sideways. Viscous diff - sometimes it will sometimes it won't. Sometimes it skitters back and forth as one wheel slips then the other.
R31 - locked diff will compromise your handling. Awesome fun for sideways action but cornering with a locker will always be slower than a proper mechanical diff due to inherent tyre slip. Slip is SLOW.
V8 supercars use locked diffs because they are cheap, not because they are the fastest way around a corner. V8's aren't the pinnacle of racing that's for sure!
:) kinks what v8s arent the pinacle of racing are you refering to circuit or drags last time i checked the fastest quater belongs to top fuel v8 draggsters not no rice cake and lemanz the tvr vanquish and corvetts are dominating not the exotic turbo snow blowers try switchin on the ol boob tube maaate yore dumming up the place :(
:) kinks what v8s arent the pinacle of racing are you refering to circuit or drags last time i checked the fastest quater belongs to top fuel v8 draggsters not no rice cake and lemanz the tvr vanquish and corvetts are dominating not the exotic turbo snow blowers try switchin on the ol boob tube maaate yore dumming up the place :P
If you had read the whole thread you would have realized that he was referring specifically to V8 supercars and not to V8s in general. I think your looking a bit to hard for a V8 Vs turbo argument that never goes anywhere... :)
I'm pretty sure most people would think its pretty dumb going on skylinesaustralia and calling turbo's snow blowers. And your le mans argument is pretty flawed because as far as i'm aware turbo diesel audi's and peugot's are dominating...
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
