Stagea Suspension
any body have or know about Buddy club suspension for the stageas ? please let me know if its worth the $2034.50 they quote dilivered to your door.
http://www.nengun.com/buddy-club/club-racing-spec-damper
how low will it go? how hard would the ride be will it fit the s1? what is included in this kit? and most of all how good is the handling.
cheers
cheers
I currently have 4 guys with Buddy Club suspension in their Skylines that I am supplying softer spring rates to in an attempt to get them some ride comfort.
:nyaanyaa: cheers :happy:
ok scrap that idea then can you put a quote together for me for every thing ill need to get better suspension for my S1 stag - the springs
figure i can just use my old ones (probly not the best but will cut cost a bit)
The Group Buy thread is the best place to start
http://www.skylinesaustralia.com/forums/in...showtopic=85592
Then PM me if you have any questions.
:O cheers :woot:
that thread is for people with half a clue about suspension.... sif i know what i need ? so for my question, what do i need with out the springs? and how much for every thing you're about to tell me i need
PM sent
:O cheers :woot:
i read about half hte thread, and i just wanted to make sure before i went and spent 450 bucks on sway bars
r33 GTR do bolt up?
Im going to be getting the cusco 24/30mm adjustables
I might be picking up a gtr rear cradle, susp, brakes, all of the above, really cheap too... I'll let you know how it goes...
what do i need to know in order to convert it...I have a bunch of mechanic mates up here with all the tools and probably all the knowledge i need, but i would love to discuss it with someone first. Take full advantage of the SAU collective wisdom.
I assume i will need:
mod certs afterwards
GTR rear end without HICAS for donor parts (which models are these - i assume it's the 34 only)
will the GTR rear driveshaft fit? or should i use the Stagea one?
I will PM Cruiseliner and SK
Edited by captinsane
  • 5 weeks later...
I thik they're the official contact for TEINs in Australia.
I suppose a fair few suspension places would do it, but seeing as I'm not in Melbourne, my info might be useless to you.
  • 4 weeks later...
a crossreference list ive made up for all the suspension components on the stagea
info sourced from FAST, cusco, JIC websites
Front Sway bar
R33 GTR
Rear Sway bar
S14
Front camber arms
GTR33
wgnc34
Rear camber arms
S14
r33
rear toe arms
s14
r33
rear traction /tension arms
s13
s14
s14
y32
y33
v35
all 32 /33/34s
a31
z33
c33/34/35
front tension rods
BNR32
BNR33
toe rods front
a31 cefiro
HC33
M35
i think that covers all of them....
  • 4 weeks later...
Front Sway bar
R33 GTR
Rear Sway bar
S14
Front camber arms
GTR33
wgnc34
Rear camber arms
S14
r33
rear toe arms
s14
r33
s13
s14
s14
y32
y33
v35
all 32 /33/34s
a31
z33
c33/34/35
front tension rods
BNR32
BNR33
toe rods front
a31 cefiro
HC33
M35
front struts for s2 r33 r34 pedders xtreme full adjustable ride hight if you have tein's such as i did you need hq - wb rear spring dampers up top to complete this conversion with standard tops not a prob !
i know that it sounds like i dont know what i am talking about but did have tein tops but did with the 3rd stagea run in perth i fractured one badly r33 strut tops all good all installed back on track looking forward to next meeting !
  • 1 month later...
Has anyone here just replaced thier stock factory shocks with another set of standard ones. Although I would love to buy SK's whiteline/bilstien setup in the group buy I have just spent so much money on the car this year so far that I just can't justify anymore at the moment. Most of the bushes have already been replaced with whiteline ones anyway (by the previous owner) and with the new nismo kit bringing the car down lower anyway I don't have any intention on lowering it at the moment anyway. So I just want to replace the clapped out stock shocks with another set of stock ones. Basically just after prices and opinions from anyone thats done it. Recomended brands etc.....
New standard Skyline shocks cost more than Bilsteins last time I checked. The standard shocks won't have the valving to control lowered springs (check out this thread http://www.skylinesaustralia.com/forums/in...=103158&hl) plus they will wear out pretty fast. Which is probably why your current (standard) shocks are stuffed.
;) cheers :D
    • I did a pretty ruthless clean up before I left townsville. If it wasn't a part to suit a car I currently have it was sold or binned. I have all my stuff organised in big tubs with lids that stack from supercheap and bunnings depending on who was cheaper at the time. Parts were sorted by either chasis/motor/Fabrication/general/electrical. I have a mezzanine that's 7mx2.3m and all lives up there. Easy to access when needed and out of the way.  I also have the issue of selling and dealing with scumplace/marketbook was actually going to list stuff today but couldn't be bothered as been stuffed around too much. I generally let a few people know I want to off load stuff and people pass it on to others to contact me, generally easy sale and I'm never looking to make big dollars. Rather it gets used than go in the bin. Next clean up will be around Xmas and if doesn't go on the s15 it's going bar 2 sets of wheels.
    • Did a little bit on the V37 today. I bought this LED kit out of the US https://www.ebay.com.au/itm/125953603618. Best I could find online but didn't look great, in the end the quality was pretty much right and it did come with locations for each light including rear number plate and a few spares. The factory owners' manual was also useful with information on where to pop each light out without damage. I prefer the LED look as I use it daily including at night and the LEDs are both brighter and the white light is easier to read with. Vanity mirror comparison, LEDs just look more modern The glove box was the only difficult one (and the only one that was previously blown.....), steps were Open glovebox 50% but not fully open Push up on bottom of the box to unclip it on both side, not screws or pins to remove Remove the top stays at an angle, right side then left, because.... Before dropping the glovebox totally, remove soft close clip on left Then, remove 7 screws to release the glovebox surround Twist the globe holder anti clock to release it from the surround In this case, the LED globe supplied was wider than factory and did not fit, so I ground down each side about 1mm then inserted it Last trick, start engine to check the LED polarity is correct, the globe only operates when the engine is running (whether the box is open or closed) I also moved the 4G booster and wifi across from the Fuga, a little frustrating as I could not find a good Accessories ACC source anywhere in the boot so I'll run a wire from the cabin next time I get a chance. Also, unlike the Fuga the external antenna wire does not quite fit between the rear windscreen and the body so I think I'll have to drill a hole in the roof to mount it. Probably not that interesting for most people so I'll just post once complete
    • Pretty sure I could do but it would need to be exported and reimported as the current import approval is race only. But in practice there are plenty of other practical reasons it can't be a road car despite their potential value these days like stripped interior looms, cage to cut out etc Nah, no mods to it other than updating the roll age to current regs. It makes about 350 (laggy) kilowatts on the N1s at 18psi which is enough to push it around the place
    • This is it, folks! Our final event of the year... The big one, you all know and love - Putty Road! It goes without saying, but this is the biggest cruise in our calendar each year! A nice long drive, with a hearty pub feed at the end! Do you need much more enticing than that!?!? So make sure you wash the car, get your cameras out, block out the calendar, and get ready! We know you're all as excited as we are, so make sure you lock in the details and date below: Date: Sunday 8th December 2024 Meet Location: Corner Windsor Road and Groves Avenue McDonald's / KFC (3 Groves Avenue, Mulgrave) Meet Time: Meet at 9:00am for a 9:30am departure Destination: The Royal Hotel, Singleton (84 George St, Singleton) Map: https://tinyurl.com/saunsw-puttyrd Itinerary: We will meet at McDonald's / KFC on Windsor road and from there will head onto Putty Road. There will be a break at the Grey Gum Cafe (8679 Putty Rd, Putty) which we should reach at approximately 11:30am. For all the Newcastle folks this will be a good point to join up. From here we will continue on to Singleton for lunch. Please remember to fill up prior to heading onto Putty Road. There will not be a fuel stop until Singleton. To those running on E85, Freedom Fuel (old United) at Vineyard on Windsor Road has started selling there. At Singleton there is a range of servo's available including BP, Shell and Caltex. There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Back by popular demand - we're lining up another Old Pac Run! Get your cars ready for one of the best night runs on the calendar! So without any ado whatsoever, here are the details for you to save: Date: Saturday 23rd November 2024 Meet Location: Cowan Truck Stop (Pacific Motorway - Refer to Map) Meet Time: Meet at 7:30pm for a 8:00pm departure Destination: Gosford McDonald's (65 Pacific Highway, Gosford West) Map: https://tinyurl.com/saunsw-oldpac Definitely an easy one for this cruise, meet at Cowan Truck Stop and jump straight onto Old Pacific Highway! Final stop at McDonald's which has plenty of parking all around. Please be mindful of the added police presence lately so best behaviour is expected! There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAU:NSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
