Well I'm not planning on lowering it for the time being, I may decide to one day maybe but I have already scraped the front bar comming in and out of some places (they have been a little steep though) and I do take the car on holidays and camping etc so I will probably just fill the guards with wheel size rather than lowering it.
But if the standard Nissan ones will cost more than the Bilsteins (and I'm guessing there is no aftermarket equivilent that are properly valved for Stagea's and not just GTR / GTS-T combo kits) then will the Bilsteins be fine with the standard springs (this may seem like a dumb question, but I'd rather be sure as suspension isn't one of my stronger points :) ).
Thanks again guys.
Yes, I ran mine for several months like that. I used the additional circlip grooves on the Group Buy Bilsteins to lower it, around 24 mm worked OK.
:P cheers :)
I dunno where this belongs
But
Any S chassis or Skyline diferential works in the stagea
I put an S13 differential in my stagea
ALl i had to do was change the input shaft for the driveshaft
and the rear cover
THen just bolt it up
you do need to find shorter bolts for the front two mounts as it will mount directly to your subframe now.
Hi SK,
what if the stock runs out for the blistein for the stagea? Will i be able to get hold of it later on down the road? Say next year?
Also howu much in differnce in price between a whiteline and einach springs? Much difference in performance?
Edited by stasis
  • 3 weeks later...
man im tellin you
my roads suck
like seroiusly dude
we have potholes, dips, crazy inclines everywhere
8/6 in a stagea is great
8/6 is too soft in a 180 to me so it is hella comfy in a car that weighs 1000 lbs more
man im tellin you
my roads suck
like seroiusly dude
i hit a bumpy road the other day traveling like 120kph and the car when all over the road!!! The suspension that i have now is JECS. And guess who OWN JECS?! Hitachi!! i think.
But yea i want to know whether with 8/6 will cause the car to go all over the road when it hit bumpy road at high speed?! Thats why Sk set up os very tempting. But the setup that i want is the one with eibach springs which costs like A$2.2k. That will have to wait till i saved up first.
your springs are like 40% of the equation
the shocks are the big thing
no matter what spring rate you have, if your shocks dont haev good bound and rebound dampning its horrible ride
well
tein is a good company becuase their valving and spring rates are more um.....less extreme
their valving isnt as harsh, and spring rates are normally 1-2k lower than other brands.
nope
all it takes is a few items
I tHINK the lower bolt is 19mm on front and rear (i think)
top 2 on the rear are 12mm
top 3 on the front are 14mm
and take it off
(after you take off wheels obviously)
nope
and take it off
ok thanks will try to change the suspension when i get the shocks late next week
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
    • Going by the intake & injectors I'd be guessing it's a DE, check the head casting number, should be 5L8 on a DET, 5L7 I think is the DE number.
