Couldn't give you any opinion on the coilovers as I have only ever had one set of Tein's in my old S13 and have never had anything to compare them with. You'll still be able to use the whiteline sway bars and as for the wheels as long as the rolling diameter is the same you shouldn't have any problems. Staggered width wheels should be fine just not staggered diameter.
And like nick said if you do have the R33GTR sub frame you can use 260RS suspension kits as the normal stagea specific kits won't fit in the rear.
Honestly I've never looked under a factory manual RS Four S to see if they have the usual GTST or 260RS style GTR subframe. I'm sure there has got to be someone on here that has. The difference is with the R33GTST subframe they use the eyehole bush type but the GTR subframe / hubs use a fork style setup for the rear shocks to mount. So yeah if you have the latter then you will need to get kits suited to the 260RS or if you have the usual GTST subframe then just the normal stagea kits.
When the car gets here you'll know for sure. Just look at the rear shocks and see if they use a bush or a for type mounting at the bottom.
the rear is fork type on RS4S.
just order the sydneykid group buy gear. problem solved. once you set the height you will almost certainly never touch it again.
if you intend going much lower than standard you are going to need more than the whiteline eccentric bushes for adjusting static camber (if you want to get reasonable tyre wear). despite sydneykid's dislike of adjustable camber arms you will probably need them.
Edited by wolverine
I myself have a 99 RS4 Type S and I also had trouble on deciding on what to do suspension wise. In the end I have come up with the following solution for my car which I have been very impressed with and also the suspension shop that did my work also commented that it appeared to be a very well sorted ride.
R33 Greddy Type S Coilovers. these are 48mm diameter monotube shocks with 36 way adjustable damping. (Had to have the Rear Billet Strut top machined to fit the standard stagea mounting as this is slightly smaller in a Stagea than in a GTR, any good workshop can do this no problem)
Front Greddy springs are 8kg and the rears are 6kg.
The rear springs are a little too soft and they are progressive which is no good for a wagon. (i swapped them for a set of off the shelf 8kg Eibach springs which is an easy swap)
Overall the ride is really nice and I find it very comfortable, I didn't notice a huge change in comfort either when going from the standard setup to this. I am not sure what the standard settings are for a Type S but the standard suspension is pretty firm in my opinion. Also you will be glad to know the Type S comes with larger Swaybars than normal Stageas although these are hollow same as on a GTR and not solid like the Whiteline ones.
All up my solution cost me about $2500, and this included paying for workshop labour. If you were doing it yourself I reckon you could do something similar for $2000. I really wanted coilovers so that is whay I went down this path but from everything I have read on the forum Sydneykids kit is very well recommended.
At the end of the day if you want a safe option then get his kit, else if you want to try something different then make sure you speak to someone who knows about suspension before you hand over any money.
http://www.nengun.com/ikeya-formula/tension-rod
got it for around $450, but I checked again and nengun seem to have doubled their delivery charges from $57 to $108 for this, perhaps better to look elsewhere, slide etc., but make sure its the 4wd bush type for RSfours, same part as GTRs.
they look like a good option. what is an indication on price?
duncan i think we fitted the noltec(i think?) ones on our car ages ago. UAS supplied and fitted. the price was pretty comparable to the whiteline caster bushes (again from memory).
call JP he should be able to clarify.
  • 3 weeks later...
A repost for those that may not have read it;
The Group Buy Bilsteins have additional circlip grooves added so you can set the height you want before you fit them. For the Stagea kit there are 10 grooves 8 mm apart and I can tell you the height that you will get from each groove. Keep in mind that Stagea handle and ride best around 360 mm front and 350 mm rear (centre of wheel to guard).
Adjustable shocks are only worthwhile if you know what you are doing with the adjustments. Most of the time shocks have adjustment to cover up for their unsophisticated valving. This means they only work in a small range of conditions and so they have to have the adjustment. Bilsteins have very sophisticated valving and consequently have a large window that they operate well in. Simply put, they don't need adjusting. Plus I have selected the valving to suite the Group Buy kit.
For the guys who want/need to change the height of their Stagea regularly then there is an option using the Group Buy kit plus a Bilstien coil over conversion kit (threaded sleave + top and bottom spring seats) with Eibach springs. It simply slides over the shock and retains over the circlip groove. Looks like this;
Rears
Front
Obviously with the Eibach springs and the wide window that the Bilstein valving allows, there is a choice of spring rates. Currently I am running 275 lbs/inch (5 kg/mm) front and 225 lbs/inch (4 kg/mm) rear, which are only slightly higher than the Whiteline rates at the front and the same at the rear. I will try 250's in the rear for towing when the R32GTST is finished its refurbish.
The coil over conversion costs around $900 and includes 4 main Eibach springs, 2 Eibach tender/helper springs, 4 threaded sleaves, 4 top spring seats, 2 intermediate spring seats, 4 bottom spring seats and 4 lock rings. C spanners for adjusting the height can be purchased from any CBC or NBC bearing shop.
Cheers
Gary
Hey,
Does anyone have any pics of SK's Suspension before you put it in the car. The ones in the group buy thread that SK posted up ages ago no longer work. Am trying to install my kit this weekend but I think the rear spring seats (bilstein ones) are wrong as the rear spring doesn't fit over them. I have them the right way up and have double checked the part numbers for the springs to make sure they are the right ones. The spring seat looks like its too big, the fronts are fine (haven't fitted yet but they sit on the spring seat fine). But if I flip the rear sping over so the flat shaved down side sits on the spring seat it fits fine but I'm guessing this isn't right?
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
