Kings Springs:
Front - KDFL- 101 (355-360mm ride height)
Rear - KDRL- 87 (330mm ride height)
- KDRS- 87 (360mm ride height)
Will let you know how I go.
approx 30% increase spring rate.
Fronts suit r33/r34,
Rears suit z32 (tapered spring ID 88mm-77mm), KDRL are 300mm or KDRS 330mm uncompressed spring length.
Kym
Hey did you end up fitting these king springs ?? how did it go ?? is that the full part number?? interested?? :D
that king springs part number for the fronts is correct as i just fitted them to my s1 RS4
the rears tho,im not sure
That part number is that for r33 gtr springs?? lows not super lows? were you happy with front ride height?? make much of a handling difference?? :(
[quote name='rx7gt' date='12 Aug 2009, 02:19 PM' post='4763566' were you happy with front ride height?? make much of a handling difference?? :(
Just checked king springs catalog and those part numbers 4 front springs were for r33/34 not listed as gtr My understanding was that front springs were the same as gtr not gts-t as gts-t is not 4wd Kings dont list a part number for gtr odd!! My car is s1 stag rs4 auto same as yours I think?? Would still like to know how the kingers panned out?? only $149 from auto barn. Cheers if you can help.?? :O
grab the whiteline R34 GTS4/GTR front springs... or lovell/king etc
Unless you can get Stagea specific (wagon) springs you are better to stick with the stockers. Most cost effective handling mod is a (much) heavier rear sway bar. Bilsteins (sometimes sold under Nismo brand) will give handling improvement and can also be used to regulate height.
Personally Bilsteins and the whiteline alignment bushes with a more aggressive alingment were my favorite mods, then springs and swaybars. Good tyres obviously help.
Yeah will be going the full suspension route later probably go the Tein coilovers(rs4 specific items) route and swaybars bushes etc can get teins for a grand. Just wanting to know how rbd2 went with those springs ?? as wanting to lower car in the meantime as its height pisses me off jeez the lower front lip is the same height as my rx7's front bumper bar.and I hate the nose up bum down look of the stag. My shocks are still good just want springs and sway bars for now.white line, kingers,apexi etc etc but will not going so low as to stuff up the geometry :P Oh cheers 4 all da info guys :P Any more spring part numbers/ brands/feed back etc Would be helpful?? cheers :ninja:
:ninja:
S-Tune springs & shocks (freshly reconditioned) and the bigger rear bar has made a big difference to my wagon. But I'm sure with brand new factory shocks it wouldn't be too shabby either...
:P
>_< Agreed :down: much heavier rear swaybar best cost effective handling mod and recommended to all!! Stag is actually fun to drive through hills!! now!1(does not handle like a taxi) Car tourque still has three of those custom rear swaybars for c34 stag 2 ajustable and 1 none. paid $260 watch out when I went to pick it up they tried to charge me $300 wtf!
Has anyone heard anything about these tein coilovers?
http://www.stageagarage.com.au/tein2dbasicwagon.html
They seem to be a very good price for a quality brand of suspension, does anyone have em or know anyone who does cause i was looking at some cheap coilies but these are fairly cheap and a reputable brand.
BTW the C34 ones
Also available from Nengun;
http://www.nengun.com/tein/basic-wagon
and RHDJapan;
http://www.rhdjapan.com/jdm-low/Tein-Basic...tagea-4WD-52229
I was considering that very kit, but got hold of second-hand S-Tune for less (including rebuilding the shocks)
I see, have you heard anything about them like what the adjustment is like.
Edit: just read about them on nengun, 20mm of adjustment that is piss weak there not even worth it.
Edited by horrace
well i had my S2 RS4S lowered this week, and had a wheel alignment, this was as far as could be adjusted with the standard set up.
what camber kits (front or rear kits/ arms) do i need to get the camber to where it needs to be?
do all the other dimensions look okay?
What specs were used for your alignment?
Here are mine:
Front caster L 6deg R 5.75
Front camber L neg 1 deg R neg 1 deg
Front Toe in L0 R0 total 0
Rear camber L neg 0.5 deg R neg 0.5 deg
Rear toe in L -2mm R -2mm
To get more caster you can get eccentric bushes but better still adjustable arms ( I think mine are GTR) ..failing that knock back the rh caster til you have a 1/4 deg less on the right than the left to allow for road camber. You may be able to reduce your neg camber with eccentric bushes as the adjustable parts are quite expensive. You should be able to reduce front toe in with the existing set up.
Your rear camber is quite excessive (might be fine for the track but may cause wear problems etc on the road) and won't be fixed with bushes but adjustable rear camber arms are not too expensive. I have adjustable camber arms and wind on some more neg camber for track days and then return it to spec for the road. You should be able to reset toe in to zero.
I have been using the above settings for a couple of years with no uneven wear issues.
eibach have a pro kit spring set listed for the stagea.
part no: 6345.140, seems to be the same as the 97 Infiniti Q45
http://www.afterparts.co.jp/eibach/eibach_nissan.html
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
