with the BC kit i've noticed there are 2 types
- BR type RS series....................... more expensive
- V1 design VS series................... less expensive
whats the better one to get???
BR's are what I have, very happy with them. Iain has the same.
Not sure if one is "better" than the other; I'd be willing to bet the damper cartridge is the same, just prettier collars on the BR's.
Edited by Daleo
what pic?
the ones on the justjap site dont look anything like the M35 ones. for a start, the rear of our car isnt a 'coil-over' type setup
yeh i just realised that again.
but if you compare them with the VS models the tops are different, so a wrong assumption by me.
looks like im just gonna get the VS's...
You don't try hard enough Iain! :nyaanyaa:
n00b question, but are there adjustable wishbones available?
Yes, but I doubt you'll need them. Camber is pretty good when you lower. I'd use offset bushes in the std arms, that way you still keep your ride quality.
Hey guys, Just into the coilover swap now.......S1 1997 RS4.
Couple of small questions, What's the difference between 34GTST and 33GTR front coilovers?
I know the spring rates are different as mentioned in this thread, but are the physical dimensions similiar?
And will a standard Stagea rear strut hat fit an a/m S14 rear coilover?
Thanks + Cheers :)
well 34 GTT (or 33GTST?) are rear wheel drive so id say different to your RS4 stagea. R33GTR physically fit. the s14 would physically fit an auto RS4 but top hats/mounts will need to be modified due to being too wide IMO. dampeners will be adjustable so you might get past the different valving in the shocks
if your buying coilovers why not just buy stagea specific coilovers?
Hey after searching and searching this thread and others, I'm still trying to find a definite coilover setup that will fit my rs4s I was looking at bc coilovers but I'm not sure now which ones I'll need Im pretty sure r33 gtr will go straight in but the valving is wrong will this make a huge difference if both the spring rate and damping is increased
Is your RS4 manual? AFAIK the manual's have the same shock bottom on the rear as a GTR (Fork-type), whereas Autos have GTST type shock mount (eyelet-type). My understanding of this thread is that R33 GTR front will be fine, but both R33 rears have wrong valving. Justjap list them specific for a Stagea with both Eyelet and Fork type rears.
Pretty easy to tell what you need if you poke your head under the back of the car and take a look at the bottom of the shock.
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
