Stagea Suspension
pretty sure the consensus on squaky suspension is the upper control arm to upright bushes
i remember someone saying that they drilled and tapped theirs and put grease nipples on them
alternatively, hit them with some wd40 and see if it goes away
  • 1 month later...
Suspension upgrade m35
Can anyone point me in the direction of a suspension business that deals with stegeas in Adelaide ?
I'm looking to upgrade my 01 m35 to poss bc coilovers seems to be the product of choice , car is used for daily use family wagon but 80k old original shocks are getting g pretty floaty with a fair bit of roll . I guess bushes should be replaced at the same time too . I'm not going to attempt the job , don't have the equip but is it a cheaper opp to buy the parts online and then find Someone local to install ? Appriciate any advice cheers
  • 1 month later...
What area are you in?
Aps, I just had all of what you're talking about done by Greg at Gregs Alignment Solutions ( http://www.yellowpages.com.au/sa/regency-park/gregs-alignment-solutions-11933600-listing.html )
Give him a call if you want to price those options up, he did a really good job - I'm super happy with the alignment. Feel free to let him know I sent you also.
  • 3 weeks later...
Any one with an s2 C34 had any problems with the front swaybar link (left hand) hitting the crossmember over bumps? I have replaced the 'D' bushes and links with new genuine (link ball joints were gone) and made a differance with handling but after a week same thing when over a big dip turning or out of the driveway. Thinking bent sway bar? Very strange i think my car is telling me it needs coilovers :laugh:
The bar could be sliding to one side causing the issue you describe.
Check it & see if it's off centre. You might need a set of lateral locks on the bar.
You are correct! I did notice the left hand little rubber thing was loose on there and the other side was stuck to the sway bar. I pulle the swaybar back to centre and hose clamped the rubber in place. Problem solvered! Cheers heaps!
That won't last. I've used the poly lateral locks years ago when I first put on my sway bar as I was having the exact same issue. They lasted a few weeks before the bar was pushing through. Make sure you don't tighten the D bush clamps until you have full weight on the front suspension. But I still had the issue on and off for a couple of years and just put up with it. I knew my factory links were pretty crap. I replaced them with whiteline adjustable links. After playing around with the links for a bit I've never heard it rubbing again.
You're right it hasn't :( it makes a massive difference to handling as well :( I did the D bushes withe the car on the ground. Will an aftermarket sway bar (33 gtr whiteline) fix the problem? How much we're the links? Got a part number?
I wonder why it does this ?
What is the dia of the front bar?
I have a set of 22mm billet lateral locks at home; but they only cost about $20 a set, so I can source them for you if you like?
I have seen people using worm drive hose clamps in tight situations, perhaps they could get you out of trouble for now?
I would go with the billet alloy ones Daleo has though, oh that's right, I did. :)
Yea that would be great Dale! Not sure what the ID is though. It's just the stock rs4s s2 c34 front bar
Tried the worm drive and didn't last long at all still clunckin around :(
I bought mine from Dale but was a while ago now. But I remember the price was good. I've also tried worm clamps on the poly bushes as well. Trust me the bar won't be the problem. The adjustable links allow you to adjust preload on either side of the bar. Mind you the billet locks weren't around when I first got my bar (6 years ago now) and I got the links because my oem ones were stuffed. Been at least 18months or more now and no more issues. So seeing as you've got new oem links maybe try the alloy locks first.
anyone suggest some places pref in melb to purchase some spring/shocks from? i just purchased a set of rear R34 GTR Nismo adjustable dampener struts, what springs would you suggest for a RS4S? are the king springs listed in the catalogue to suit R33/R34 ok or not stiff enough?
Cheers
  • 3 weeks later...
So I've read about 30+ pages and scoured the Internet for a few weeks and I can't find my answer.
Ebach and whiteline don't sell springs anymore. And shipping from Japan is too expensive.
What lowered springs fit the standard stagea shocks?
I plan on doing sway bars and lowered springs. As my 9.5" rear rims are a finger gap away from the standard strut and I doubt coilovers will fit.
Sorry! i can't edit my posts.
I've read about 30+ pages and scoured the Internet for a few weeks and I can't find a definitive answer.
I don't think i can use aftermarket coilovers as i only have a cm of clearance from the stock shock to the rim and i have a cm of poke so i can't use spacers.
I've read a few threads where people say that 33gtr front springs and 33gtst rear springs fit the standard stagea shocks. But from reading these posts it seems as though they're confusing springs with shocks with coilovers, as everyone has said the 33gtst rears have a larger top hat. So in theory the springs will not fit the standard stagea shock?
The stock stagea spring rates are Front - 2.9 & Rear - 3.1 Most aftermarket spring rates are in the mid 3's F&R So this should compensate for the heavier rear end?
Please i really need some help as information is scarce!
I would like to track the car, but it will probably never happen, most of my driving is at the posted 70kph with plenty of round abouts and sharp corners, I like the car to feel less boaty (rims made a huge difference), this is my reason for harder lower springs and sway bars. Just coilovers wont give as good of an upgrade, is this correct?
I've tried to give as much information as possible.
I've also emailed a few companies but have not received any replies.
    • Great to know! The guys from The Skyline Shed are going to sort it out and send what I ordered anyway. Turns out their supplier sent them the wrong stock.  But it's good to know I "can" put this in if needed
    • You do not need an LSD oil in any stock (non-GTR) diff, even if it is an "LSD". This because none of the (non-GTR) LSDs are clutch/friction type LSDs. Either viscous or helical - neither of which require an LSD oil.
    • Hi everyone, I bought the Redline diff oil and the seller has sent me Redline 75W90NS even though that’s not what’s pictured.  I’ve already booked a hoist to go and change my diff tomorrow but I’m not sure if the NS is ok for the rear diff in a R34 GTT I think the NS does not have any slip modifiers so would that be an issue?    thanks in advance
    • Not easy to find pics from 15 years ago, but here is a partial one. Keep in mind that it curved immediately from the airbox, then kept a straight line for the MAF to read correctly, followed by a 45 degree bend straight down to the turbo. This connection was the most difficult as it had to twist as well as bend to meet the almost vertical straight section of the intake.
    • Yes, well, wrt a wheel alignment, there are two types. Either: You have very little added adjustables, in which case the alignment can be done by anyone in any tyre shop or equivalent, and will only take 30 minutes, and so there is no reason to even consider leaving the car there. OR: The alignment is a major exercise because you have adjustables everywhere and so you will need to be taking it to a shop that is skilled and experienced at setting up race cars and the like, and you won't need to worry about leaving the car there.
