1 hour ago, GTSBoy said:
I think you'd be surprised. The quality of the damping is very important (which MCA obviously take some care over). This is the reason I do not like Teins, because even with 8/6 kg springs, I think their damping is rubbish.
MCA are in the camp of "very high spring rate, low ARB rate". Hence the really heavy springs on their gear. I think Gary's approach was from the opposite camp, which is to keep the spring rates lower and control roll with bars - although granted my only association with him is wrt to his B6 based setup for street Skylines and for that he was constrained to use off the shelf stock format springs and stock format mass market dampers (albeit revalved for improved performance). It's very much a horses for courses thing though, as both approaches are ultimately compromises that will favour one usage model over another, and they do not end up being totally equivalent to each other.
Yeah, they mentioned that its not worth upgrading from the stock sway bar due to how their coilovers are set up.
Still learning more about the suspension etc, but with Garys approach of lower spring rates and controlling roll with bars and obviously improved dampers, wouldnt that be like softer ride and more roll but with the sway bar, it keeps the roll to a minimum/lower amount?
Where as MCA's approach of stronger springs, and dampers adjusted for the springs, wouldnt that be a harder ride (against bumps, going straight etc) and less roll, and the stock sway bar does its thing but the coilovers does the majority of the work?
Its a daily so im in favor of a softer ride while normally driving but keeping the roll to a minimum while turning etc. Or am I getting my idea of suspension completely wrong?
37 minutes ago, Stick180 said:
This is completely different to their OG approach. I have the R&D/guinea pig  set of MCA Blue coilovers in my stagea from about 9 years ago. Josh started with a rough R33 spec valving figure and spring rates (which was 10/8kg). We went for a whiteknuckled test drive through the Landsborough hinterland before he decided needed more valving and less spring. Eventually settled for 7/5kg springs and a bunch more valving (unsure of figures). I was running on some Tein Superwagon coilovers at the time and the difference was night and day. And after going for a ride with a fellow stagea chum who runs BC golds, i still believe the MCA Blues i have are still by far a better ride.
As for Voston, as far as i am aware, that is their budget brand and nothing like the Pro series they offer now, or anything like the Blue/Red or Gold series back in the day
I was looking at the Pro Comfort, it has the price hike of it being the MCA Pro series ( extra $400, total $2490 ). Ive read people saying the blue/red/gold series(and the blues being more favorable from the past threads) but what would those be nowadays?
What was the drive difference between the BC golds and the MCA Blues you got?
Unfortunately this is a bit like arguing if you prefer blondes or brunettes....you will get people who strongly hold either view.
My observation is I have had good results racing on MCA golds (spring led) but personally find Gary's approach of lighter springs and heavier bars is more predictable over mixed or rough surfaces like in rally (or an Australian road)
Personally, i'd be dropping the extra $400 for the Pro series. I believe (at least during their original conception) they were based off the Blue series but have evolved with apparent new valving tech etc etc.
The BC's were super harsh ride wise, felt like the road was covered in potholes almost (this with damping at softest), but they did feel a bit more pointy initially through corners, i felt like there was considerably more understeer at turn in on tighter radius corners (but this is not really a like or like, considering the difference in wheel size, tyre choice, track temp etc etc)
The main argument for lighter ARBs is that ARBs reduce the independence of the suspension. They link the left wheel to the right wheel. The lighter the ARB is, the less this linkage. When you hit a significant one wheel bump on a car with lighter springs and heavier ARBs, more of that disturbance gets transferred across to the other wheel. Whereas, with a heavier spring and lighter ARB, the impacted wheel is the only one that reacts to the hit.
If you hit a significant two wheel bump, then lighter springs are the only things taking the bump as the ARB is not involved (both ends move up/down together). Then the spring rates alone determine how the car takes the hit. Softer springs (to a degree) will be more comfortable. Harder springs will accept the energy input better with less total compression (but obviously possibly more undesirable and probably uncomfortable body movement).
The other significant thing to remember is that spring rate is really about coping with the rate at which loads are input to the suspension. Driving around slowly? Then any bump you hit is going to feed load into the suspension at a low rate, and you can use a low rate spring and with a low rate spring the damper has to less work to control the spring's motion. This describes street usage because it is mostly illegal to go fast or drive aggressively enough to require handling fast load inputs. But if you're going at racetrack speeds (or rally, or anything where going fast over whatever the surface is) then the loads get applied faster and you need to control that input with more spring rate, and then the dampers have to do more and that's why it all starts getting expensive. Anyway, the point of all that is, it's complicated, depends on usage and surface quality, and it's why proper race cars have a lot of adjustment and will even completely swap out springs and dampers when going from one track to another. One track might be smooth, and so even if it is a fast track there won't be rapid load input. Another track might be as rough as guts, or it might have a couple of sets of tight esses on it that require the car to heave from side to side. The rates at which loads get fed in will be different on those two tracks and probably require completely different setup.
Three paragraphs and 400 words are nowhere near enough to convey how complicated this subject is and also I am nowhere near the right person to write a treatise on it, as it it not my field of expertise, or even keen interest. There are many books written on the topic, and as alluded to previously, they take differing approaches to accepting the compromises involved. So you can't read just one and think you understand.
  • Like 2
Thank you, this was comprehensive and I consider myself an expert on the subject now.
Regards,
The Internet.
Suspension really is complicated.... All these considerations are making me over think it all. Again.
I reckon I'll wait for SK's response on his coilovers, and go from there. Though if I go MCA, I'll have to decide on whether the extra $600 (voston comforts $1890, mca pro comfort is $2490) is worth it. Just something soft and comfy, yet firm enough when required at the track or a casual old pac drive for a pie...
Otherwise, anyone have experience with SuperPro bushings? Needing to replace the bushings on the suspension department... Will probably keep the oem uppercontrol arms etc, and just replace the bushings.
Superpro are fine. There are some applications (R32 FUCAs for example) where they are no damn good, but typically for any normal suspension bush, they are fine. Some people will complain of them making noise. Some people will complain of them collapsing. But many of those can probably be traced back to not properly lubing at install or other installation problems, or possibly other problems elsewhere in the suspension that put additional load into particular bush. And for the legit complaints? Meh. Deal with it. I had to replace the poly bushes in my R32 FUCAs every year.
The real issue is that I am sold on the idea of adjustability of at least upper arms. So I only have spots for poly bushes in lower arms these days, as everything else is either hardened rubber or spherical steel.
  • 3 weeks later...
I currently have someone who is interested in buying the rear set, plus he has asked me to quote him on an equivalent front set, new of course.   I'll post up what a new set would cost and you can make a decision then.
I noted a bit of discussion on spring rates versus swaybar rates, Duncan has explained my approach very well.  What I would add is that if you have high spring rates then it is a PIA to change them if you want to, say, do a track day.  Whereas with adj swaybars it's a much easier task. Plus if you find that there is an imbalance in the handling (oversteer vs understeer preference for you) it is relatively easy to change the balance with adj of the swaybars, again much more difficult with springs.
On the race cars we don't change spring rates all that often, we do however change damper rates frequently, high speed vs low speed bump and rebound independently.  A tuning task not for the inexperienced, driver or engineer.  Driver adj swaybars are adj frequently, several times in 20 minute race is not unusual.
Cheers
Gary
On 15/4/2024 at 7:11 AM, Sydneykid said:
Hi guys, I do have set of rear Stagea Gen1/2 Bilsteins revalved, only used as a test fit for a couple of days.  They are height adj coil overs, used strut tops with new sphericals and Whiteline stacked springs, a helper/tender plus a 265lb main spring.
If you need fronts I can still source them, but delivery is from Germany so not overnight.
Cheers
Gary
Hi Sydney do you still supply the spring and shock i want to change my coil overs to the your set up please advice
Cheers
Gary
Hi Gary,
I would be interested in the Bilsteins. I've recently purchased a 260rs and need to get the suspension sorted. Can you pm me to discuss?
well, Gary doesn't own a suspension shop (any more) and I think he is choosing when to engage/how much time to put in to SAU or selling kits, which is totally his right.  He has shared a huge amount of experience on here over the years from both his direct knowledge of the suspension of these cars, and from being part of a serious effort to race R32s and all of that written knowledge is still available here, so I totally understand him not wanting to answer 50 pms a day for what is essentially a hobby.
Heasman's in Sydenham for those in Sydney, or your local Bilstein dealer elsewhere could also assist with Bilstein based kits, noting they would not include custom revalving but would still be generally suitable for these cars.
  • Like 1
On 31/05/2024 at 10:13 PM, Shortyesquire said:
Hi Gary,
Hi, I have someone interested, if it falls through I'll let you know.  I have a brand new set of fronts that  I sourced from Bilstein UK, now revalved and complete with springs to go with the very lightly used rears, if you are interested in a full set.
As Duncan has mentioned this is not my job, I sold my suspension business over 10 years ago, but I am here to help when I have the time.  To give you some idea of my schedule I was at SMSP for the State Championship for 4 days the weekend before last.  Then The Bend for 4 days last week and back at SMSP testing this week, a day visit to One Raceway, then the SMSP Day Night meeting the weekend after.  I was hoping to squeeze in a dyno day with Scott on my R32 this week, but that's not going to happen, that's the second time I have had to postpone.
Apologies if my responses are slow.
Cheers
Gary
Cheers
Gary
No worries.
I have a set of Zeals to get me through for the moment but would definitely be interested in a full set of Bilsteins.
Are you doing race support these days? I drove past the Bend when I picked up the 260 rs but never driven the course. How does it compare to SMSP? I'll be at SMSP tomorrow afternoon and on the 26th of June in the morning. I'll be in a very loud (straight through exhaust and straight cut gears) silver R35 GTR.
Cheers,
Andrew
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
