Next week i'm getting GTR camber arms fitted to fix my rear camber. meaning i can have a low car and not have any camber. will show before and after results for interested parties
hey mate is that the main top arms that have a big O shape for the shock to go through? cause they dont fit as the shock hits em, as i tried putting the ones from a gtr rear cradle, so i used the stock stagea ones again which are just a str8 piece with a few curves on it.
They don't have an O-shape, they're curved however to go around the shock.
The rear of the stagea is setup the same as an R33 GTR correct? well i saw them installed on an R33 GTR so i guessed they'd work.
anywho, my mech will be fitting them, if there was going to be a problem he wouldn't be suggesting them to me (he's been under my car enough times to know the setup, he put my coilovers and whiteline bars in)
heres a pic of a 32 gtr one, not sure what the 33's r like, but i know for sure the width of the cradle compared to the gtr and the length of axles r different to gtr's, and shocks r on a different angle all together. that arm looks exactly the same as the stock stagea ones anyway so should be fine, unless they are made with the same bends to clear the shock as a gtr and then it wont fit. only one way to find out :D
sorry the pic is soo big..
Are you really going to run spherical bearings on the rear of a Stagea?
Ask you mechanic about NVH? Sphericals are damn noisy, particularly with a big rear sound box of a waggon.
Ask you mechanic about subframe cracking? Spericals have no give, hit a bump and it is 100% transmitted to the subframe.
Ask your mechanic about wear? Spherical bearings NEED maintenance, they get dirt, grit, sand and mud in them and they wear out FAST. They have to be cleaned regularly, then greased.
Ask your mechanic about replacement sphericals? When they wear out (which won't be long) they will need replacing, make sure you don't have to buy complete arms. Many suppliers use unique spherical which you can not buy as spare parts.
There is a thread in the supension section if you want more details.
:D cheers :P
Sorry, these aren't the ones i'm using, they were just an example.
he told me he's using good quality ones, not crappy ones that clunk etc. i can get the exact details off him, but i'm not a suspension mechanic so i won't pretend to know much about what he's doing. he just said it will fix the camber and make it very highly adjustable in the rear end for future reference (in case i make the worlds first drift stagea or something)
As i said, not suspension mechanic.
he's going to sort it out, he knows what he's doing. he's been under my car a fair few times
LOL, I hear ya! Best of luck with it mate, seeing youve had the 'trouble' for a fair while, I hope you can have it all sorted and ironed out. She'll be right....... :rolleyes:
Doing my stuff this Monday at home with a fella (for a small fee), hopefully just by adding the Bilstein shocks at standard height (maybe just one groove down at front) with stnd springs, wont have a camber issue, or tyre wear etc.
Cant wait to test it all out afterwards!!!! Had my power button on today, and with 160awkw she really cranks in the lower gears, so with the suspn & wheels/tyres freshly sorted me thinks a good Hills run is in order. :D
hey sydneykid, just a couple of questions, now that im actually able to drive my car for the first time with the new suspension, its really really stiff, and ive got both front and rear on the highest circlip possible, which is 350mm front, 360mm rear. how tight does the main top nut on the shocks have to be? ive got like 40mm of threads hanging out the top of the nut. can u adjust the stiffness at all?
it handles awesome and sooo responsive when steering around bends, just i cant rev it past 4k so i cant give it heaps just yet. :P
the new suspension, its really really stiff - it handles awesome and sooo responsive when steering around bends
Yeah, I find my shocks (stnd springs) are stiff when driving at 60kmph (potholes, bumps etc), but at 80 it is very nice, and at 100 it is schweet-as! Overall a top suspn package, and totally worth the $$$$
Well turns out while i was getting my camber and other thing sorted my worst fears were realised. all of my wheel bearings are shagged and also my CV boots have gone. my steering rack is moving in the joint and my lower ball joints on both sides of the front end are moving around. looks like suspension overhaul time for me. i have done 160,000km on the car, and not much of that was easy city driving, so i guess i should have expected it.
  • 1 month later...
hiya all i was jus wondering without looking through the whole thread page by page, are series 1+2 the same for sway bars? as i have the shock side of things sorted (adjustable koni) but feels a bit boatish in heavy cornering! also are the camber arms the same? as i would like to get some adjustable ones for the rear at some stage.
Stabilisr bars are the same on S and S2.
They are $219 each for adjustable on the Group Buy and $194 each for fixed rate bars.
Stabiliser bars are the best bang for buch handling upgrade you can make.
:thumbsup: cheers :(
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
