any body have or know about Buddy club suspension for the stageas ? please let me know if its worth the $2034.50 they quote dilivered to your door.
http://www.nengun.com/buddy-club/club-racing-spec-damper
how low will it go? how hard would the ride be will it fit the s1? what is included in this kit? and most of all how good is the handling.
cheers
cheers
I currently have 4 guys with Buddy Club suspension in their Skylines that I am supplying softer spring rates to in an attempt to get them some ride comfort.
:nyaanyaa: cheers :happy:
ok scrap that idea then can you put a quote together for me for every thing ill need to get better suspension for my S1 stag - the springs
figure i can just use my old ones (probly not the best but will cut cost a bit)
The Group Buy thread is the best place to start
http://www.skylinesaustralia.com/forums/in...showtopic=85592
Then PM me if you have any questions.
:O cheers :woot:
that thread is for people with half a clue about suspension.... sif i know what i need ? so for my question, what do i need with out the springs? and how much for every thing you're about to tell me i need
PM sent
:O cheers :woot:
I might be picking up a gtr rear cradle, susp, brakes, all of the above, really cheap too... I'll let you know how it goes...
what do i need to know in order to convert it...I have a bunch of mechanic mates up here with all the tools and probably all the knowledge i need, but i would love to discuss it with someone first. Take full advantage of the SAU collective wisdom.
I assume i will need:
mod certs afterwards
GTR rear end without HICAS for donor parts (which models are these - i assume it's the 34 only)
will the GTR rear driveshaft fit? or should i use the Stagea one?
I will PM Cruiseliner and SK
Edited by captinsane
  • 5 weeks later...
  • 4 weeks later...
a crossreference list ive made up for all the suspension components on the stagea
info sourced from FAST, cusco, JIC websites
Front Sway bar
R33 GTR
Rear Sway bar
S14
Front camber arms
GTR33
wgnc34
Rear camber arms
S14
r33
rear toe arms
s14
r33
rear traction /tension arms
s13
s14
s14
y32
y33
v35
all 32 /33/34s
a31
z33
c33/34/35
front tension rods
BNR32
BNR33
toe rods front
a31 cefiro
HC33
M35
i think that covers all of them....
  • 4 weeks later...
Front Sway bar
R33 GTR
Rear Sway bar
S14
Front camber arms
GTR33
wgnc34
Rear camber arms
S14
r33
rear toe arms
s14
r33
s13
s14
s14
y32
y33
v35
all 32 /33/34s
a31
z33
c33/34/35
front tension rods
BNR32
BNR33
toe rods front
a31 cefiro
HC33
M35
front struts for s2 r33 r34 pedders xtreme full adjustable ride hight if you have tein's such as i did you need hq - wb rear spring dampers up top to complete this conversion with standard tops not a prob !
i know that it sounds like i dont know what i am talking about but did have tein tops but did with the 3rd stagea run in perth i fractured one badly r33 strut tops all good all installed back on track looking forward to next meeting !
  • 1 month later...
Has anyone here just replaced thier stock factory shocks with another set of standard ones. Although I would love to buy SK's whiteline/bilstien setup in the group buy I have just spent so much money on the car this year so far that I just can't justify anymore at the moment. Most of the bushes have already been replaced with whiteline ones anyway (by the previous owner) and with the new nismo kit bringing the car down lower anyway I don't have any intention on lowering it at the moment anyway. So I just want to replace the clapped out stock shocks with another set of stock ones. Basically just after prices and opinions from anyone thats done it. Recomended brands etc.....
New standard Skyline shocks cost more than Bilsteins last time I checked. The standard shocks won't have the valving to control lowered springs (check out this thread http://www.skylinesaustralia.com/forums/in...=103158&hl) plus they will wear out pretty fast. Which is probably why your current (standard) shocks are stuffed.
;) cheers :D
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
