i own a S1 RS260, and im looking around at Whiteline parts to improve the handling.
Ive been searching this thread for a while, and as far as i can find:
the rear swaybar is a R33 GTR item?
the Rear Strut Brace is a Stagea item?
the Front Swaybar is a R33 GTS item?
the front strut brace is a Stagea Item?
the front cradle bushings are a R33 GTR item?
the rear control arm bushings are R33 GTR item?
Can someone please confirm, remembering this is a RS260 not a RS4.
hey all,
i'm sure this has been covered but what kind of springs can i put on my s1 stagea rs4 to lower it as much as possible.c myabe just past legal in WA. my mate mentioned something about the rear springs having to be from an r33 skyline and the fronts from a 34, or somehting along those lines. if you can help please do so.
and please don't waste your time telling me to use the search function, if you can asnswer my question please do.
hey all,
There is no short answer. Start reading this thread from the beginning - you will only have to read a few pages to get the picture.
hey all,
either a whiteline stagea specific spring OR get some new shocks machined with extra circlip grooves OR look at Tein superstreets (pretty sure they are height adjustable)
Does anyone know what the valving was changed to in the rear bilsteins? I want to purchase a set and just wanted to have as much info as possible for the suspension shop.
I would get a set through SK but he seems hard to get hold of (pm or work email) and not sure if hes even still supplying them?.
If not is it ok just to use the R33 bilsteins as they are, from what I can understand (I'm far from an expert) SK said they should be alright with standard springs or if the spring rate isn't changed by more than 30%. Is this correct??
R33 is a car Stagea is a wagon so you need quite different suspension front and rear. If you can find a proper Bilstein agent they should be able to set up the shocks according to your requirements (max comfort, 10/10ths cornering power, or whatever you tell him.
Hey Guys, thought this might be of interest, just rang Heasmans in Sydney about some bilsteins for the Stagea, told them it was a 98 S2, he didn't even question the car model, put me on hold for 30sec. came back and gave me a price of $285 each for the front $235 for the rear, no mention of GTR, GTS-T. Said he had them in stock.
Going down tomorrow to check it out
the rear cradle bushings are a R33 GTR item?
anyone????
  • 3 weeks later...
anyone????
Well i can answer the rear strut brace Q
RHD has most things at great prices(when the exchange rate is good) and ships nice and quick
For future reference:
Cusco: http://www.rhdjapan.com/jdm-low/Cusco-Alum...ar-Type-OS-9597 360delivered (on the 27/2/09)
Greddy: http://www.rhdjapan.com/jdm-low/TRUST-GRed...Strut-Bar-11320 290delivered (on the 27/2/09)
You are viewing a Trust Greddy Aluminum triple tube Rear strut bar. Due to the triple tube design they are more rigid than the Cusco (only twin tube) units that we have for sale as well. The Greddy imprint in the bar is very attractive and bold. It is the only bar that dares to put its brand name right up under the hood and in your face. Only Trust Greddy, no other!
I was hunting around for suspension/shock stuff - since the price of the aussie dollar is crap i can't get coilovers...I was looking at a bilstein catalogue online and found this:
Stagea (WGNC34) Kombi/Station Wagon 4WD - 03.97- FRONT: BE5-2590 REAR: BE5-2589
I was wondering if that is correct - maybe SK or others can confirm..
Yeah, I have seen it before too. Apparently they are much harder to get.
Heasmans, (the Aust distributor of Bilsteins) recommend
B46-1471 for the front (r32 GTR)
B46-1916 for the rear (r33 gts-t)
apparently they have fitted quite a few $1144 for the full set
Go to quadrant in berwick, i MIGHT be able to organise a SLIGHTLY lower price through a suspension engineer i know, but its a big MAYBE
he will also get them valved to suit, as he has driven mine and told me what to change it too for stock springs :glare:
PM me if interested
for future upgrades, this looks to be the best off the shelf setup for a street car, spring rates look perfect as does the height. http://www.rhdjapan.com/jdm-low/NISMO-S-Tu...34-4WD-AT-56129
Nah imo the spring rates are too soft and that is alot of money for essentially a non adjustable setup that will only lower the car around 20mm.
You would be far better off going and buying some good dampers e.g. Bilstein / Koni and a set of matched Eibach, Whiteline or Lovells springs.
I don't know why everyone is so nervous about suspension don't be scared to go and match your own setup to get the ride you want. Any good suspension shop can advise a reasonable setup depending on your requirements.
I recommend the following. If your not getting a matched set of coilovers get the best name brand dampers you can afford. Then buy a set of off the shelf springs and specify your rates. Good spring manufactures offer almost an endless variety of weights / diameters depending on your requirements. The main thing is you just have to know what you are going to use your car for and match the rates accordingly.
3-4kg springs are only slightly firmer than std good for street driving imo
I run 6.8kg rear and 8kg front but my car is manual and I plan on running it in a few track days so I wanted a firmer setup, still reasonably comfortable for street use though. (My rates are based on the nismo setup for the RS260)
I have heard of people running up to 10 and 12 kg springs in a stagea. This would be bloody hard though and not what I would recommend.
I got a response back from Adam at Tuspeed yesterday for price and availabilty of Bilsten Stagea shocks (as mentioned in my privious post)
Apologies for the delayed response. Definitely can get them - price is
$325 per shock. They need to be ordered in - will take approx 6 weeks from Germany, Let me know and I'll get it all organised
so $1300 for the full set...hmm..
try quadrant, centreline, GT, etc
i got 32GTR front, 33GTST rear... will need a valving change at some point, but were in stock
i got sent stagea shocks by SK and send em back as they were the same as the ones i already had!
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
    • Keen to see the turbosmart data, to date I've only seen negative things in terms of response for them. Very small sample size though.     Hawkins is a big advocate in his videos of the larger rear housings. I managed to make similar power with a lower spec motor on the smaller .8 rear, keeping decentish spool.  The people he works with now are big power cars compared to mine though, mine really is setup to drive around and enjoy.  I don't have any back pressure monitoring though, so couldn't say if its good or bad on my car, just that it does what I want it to do.   Future I want a higher compression more cubes motor to give a bit more bottom end and hopefully the new g35-1150 gets me to the 850 rear comfortably.  But maybe I won't due to exhaust back pressure.
    • No, I refuse to buy their cheap ass crap! I do need to order a bunch of different nuts/bolts to refill my nut/bolt wall though. Maybe you could go for a walk through Bunnings for me? (Or send me some stuff from your work? )   I really struggle to work out how the US standardised to Metric in what the 70s or 80s, and yet, half a century later, there's been little done to actually bring it into fruition. It truly baffles me    On the whole Fastenal thing, I went reading their site (My god they sell a lot of varied stuff!), and it seems like it really depends what store you're near if you can walk in and just grab a few small things, or if that branch is primarily distribution with only a small window of "counter time" available (if at all). That definitely makes it harder, as move locations and it drastically changes your ability for success   For things like your M6x1.0, if you want to work on your own Skyline, and you also have a "home workshop" I'd recommend setting yourself up a small Nut/Bolt wall/section. It doesn't even need to be big at all. Most things depending on the diameter, will be a specific pitch, like the M6x1, M5x0.7 etc. Bigger bolts is mostly 1.5, except for a small number of things and that will come down to torque. From memory bolts for the brake calipers (and other things that need a lot of torque) will end up being a 1.25mm pitch. Save up a few dollars, and order a range of nuts/bolts. If you want to minimise cost a little, buy something like M6 x 40, and M6x70mm (1mm pitch) in both. In addition, buy yourself an M6x1mm thread chaser. That way you have long bolts that you can cut down to size, and then chase the threads out. Funnily enough, I find what I'd pay here for ordering 5 bolts, I can pay about 50% more and you'll get 100 of them.   If that doesn't quite work out due to space / ability to buy plenty up front, then each time you need some bolts, order 100 of what ever you're getting. Put them in clearly marked containers. Over a few years, you'll acquire plenty of different sizes, and will end up ordering less and less. And the cost for 100 bolts won't be much more than you paid for your 5 you needed to order anyway  Just takes a little planning ahead, by investigating what nuts/bolts you'll need, and ordering them before doing the job.     Edit: If it's also primarily for working on just the Skyline, for some reason my brain is screaming that at some point, either Nissan, Nismo, (Or possibly a third party) was selling a "kit" of every nut and bolt in a Skyline, purely for people restoring/rebuilding. It'd likely be quite expensive, but would give you every/any nut/bolt you need for stock/factory things. I'm not sure if it's still available, or even if it actually fully came to market, it's just something niggling in the back of my brain that you could look into further if that sort of thing interested you? (It might have been for the R32 GTR or something specifically too, and not just any Skyline)
