  • 3 weeks later...
I know this is a bit late, but I have read through this topic and am a little confused. Every bilstein part number that someone puts up differs from another persons. Also I have read people saying that rs260 has different rears, the fork kind? My RS4S has the same (I think) so that throws another spanner in the works. Also reading on the bilstein website about the part numbers and the Stagea part numbers are different all together then any R33 numbers. So confused! Also tried getting the part number on the website in but was told they don’t get sold in Australia.
Any clarification would be awesome. Also if anyone has a pic of the fork style and the other style just so I know that I’m not imagining it would be great.
Thanks Guys and Girls.
yes correct RS260 and RS4-S use the same rear shocks, which have a fork at the bottom rather than a 'loop' or eye.
To the best of my knowledge the bilstein shocks have to be ordered through SK, as it is not a stock part, rather a GTR shock that is re-valved to suit the wagon to SK's secret specs. I've got a set of the rear shocks form him sitting in my garage awaiting fitting (been there for over 4 months now).
With reisea's query above in mind...............
Just wondering if your rears have this number on them? These are fitted to my S1 260RS. Have'nt found the number for the fronts yet but in anycase if the custom valving is not recorded by this part number you will still need to contact the guru. (SK)
Cheers GW
I just tried to install the Whiteline swaybars recommended in this thread by SK.
WARNING - The rear bar does not fit. C34 stagea rear is not same as R33 gtst as explained in this thread. It is 2inches too narrow.
The correct rear bar to get is R33 GTR
Hopefully this will save some other poor idiot like me who buys parts based on knowledgeable advice
Thanks :thumbsup: Is that to say (forgive me for not re-reading the entire thread) that a R33 GTR rear swaybar will fit C34 stagea? (RS-Four auto if that makes any difference) because the stagea-specific bars have dropped off the whiteline list and the Selby ones are *very* pricey in my area. But R33 GTR would have a few more options.
Weird question? Cant be ass'd looking thru the whole thing!
Does anyone know what airbag suspension is like to drive with? Thinking of turning my Stagea into a cruiser V.I.P style car... Not sure yet, cops are turd around here.. any jap car they see they pull over and rape them.
Not speaking from experience I should think it would be fine if done properly (but probably illegal in your area).
Just after some ideas/thoughts from you guys.
The front lip of my car was sitting at about 9cm on lowered springs when I purchased the car, I've since had these swapped over for some stock V35 springs and its not at about 13cms in the middle of the front lip. I was hoping I'd get a little more out of them than that, as apparently they're the same spring as a stock M35. My car does have a kit, so that coul well be playing a role, but other than that does anyone know how high the middle of the front lip should be on a stock standard M35?
Does anyone have some experience with the BC Coilover kit ( http://justjap.com/store/product.php?produ...at=0&page=1 ) and know how high I might able to get the front? I dont think I'll be able to get it up my drive way until I hit about 18cm or possibly higher :P I'm going to shoot them an email asking pretty much this anyhow, but thought if I could get some standard numbers of you guys and any learn from your experiences it might make this all happen quicker/smoother :P
Does anyone have some experience with the BC Coilover kit ( http://justjap.com/store/product.php?produ...at=0&page=1 ) and know how high I might able to get the front? I dont think I'll be able to get it up my drive way until I hit about 18cm or possibly higher :) I'm going to shoot them an email asking pretty much this anyhow, but thought if I could get some standard numbers of you guys and any learn from your experiences it might make this all happen quicker/smoother ;)
Hi Dunc, I have them in my nm35, I'm off to bed now :P but I'll post some detail for you in the morning. My car was totally stock suspension before these so I can give you an idea of std ride height.
Cheers, Dale.
Hi guys
I have a 34 stagea RS4.
I've got a really low bar on the front of my car so want to raise the front a bit. I've been given some R34 GT-T standard front and rear shocks. I'm not really worried about the back but want to raise the front. I've gone to put the fronts on but they seem too long to be able to be put on without taking apart the suspension. I've tried using spring compressors but they won't fit on while putting the strut in as its such a tight fit.
Should these shocks fit? It says at the start of the thread the standard ones are the same as the R33 GTR, are they shorter? The ones on there at present have RS+R on the springs are they the standard RS260 struts?
Thanks Scott
Hi Scott, I see it's your first post - welcome!
I assume you mean C34 stagea as I don't know of a m34 model (C34 or M35). The C34 shocks are covered in detail throughout this thread; but basically in summary I am pretty sure the fronts are R33GTR, rears are R33 GTST (but the valving of the rears is *not* suited to the stagea - they just physically fit). One way I can think of to raise it might be to get hold of some Bilstein shocks as they have a circlip-located spring seat which is height adjustable; you can read all about that here http://www.skylinesaustralia.com/forums/St...lin-t85592.html
EDIT: Ah do you have a 260RS? If so then the rear shocks need forks, not eye bolts... see above-mentioned thread for details and have a read through here re. RS260
PS You might actually have to "lengthen" the bump stops lol. Raising the C34 has been discussed before - have a search through this thread.
Edited by DaveB
I can't find any specific mention of R34GT front shocks being tried (it is mentioned however that R34 rears are forks and thus will only fit a manual stag') though the thread is long and I haven't searched much. However SK does make it clear that the valving is all wrong for a wagon with '33/'34 shocks at the front.
Yeah I was trying to look through it all too and that's the only mention of the R34 I could find as well. Looks like its a no go either way. Guess i'll have to source so R33 GTR shocks. Thanks for your help and interest Dave.
  • 3 weeks later...
I already have new Bilstien shocks front and rear, so I guess Im lucky in that respect, and fingers crossed if I ever need new ones I cn match the part numbers.
But I'm thinking of new wheels and lowering it a bit. Have people figured out what is needed for the 260RS front and rear spring replacement? Thinking King Springs or Tein.
Ie, body type/part numbers/and spring rates if needed seeing it is a wagon etc.
Much appreciated :ninja:
If you have Bilsteins you don't need to change your springs. You can adjust the height by moving the circlip up or down. If you have run out of grooves (only likely if you want an extremely low setting) you can get more grooves machined quite cheaply.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
