  • 3 weeks later...
Hi guys, Im looking at getting a set of coilovers for my series 2 WC34 stagea RSfour
How do I know whether I have the forked or eyelet rear suspension?
I have the AWD tiptronic 4 gear auto which makes it the RS four V? making it the eyelet rear suspenion?
Thanks heaps for any help!
Edited by Spoonman
hey guys a fellow stagea member is selling his coilovers from a 99 s2 AWD factory manual..
i have a 97 series 1 auto awd.... any chance the coilovers would fit? they are HKS hipersport 3's.
from what i am reading factory manual suspension isn't compatible?
I wouldnt know what I was looking at mate.
Is there no way to know based off model type?
Then Google image search the difference so you can see it yourself.
It is a big easy to spot difference
You could go by model. And that would probably work.
Bit to be 100% sure you need to look for yourself.
Who says that something hasn't been changed in the past for some strange reason.
  • 3 weeks later...
  • 2 months later...
I have been going through this thread for the last few days and can't seem to find the answer. I know it would be here somewhere but I obviously can't see it. I have a 99 RS4S and the front shocks are rooted. I can't seem to find part numbers or brand choices for the RS4S. Any help would be great cause the shops up here in Townsville only seem to want to help if I can get them the part numbers to save them doing a search or calling around for me. Need help as soon as possible cause I need to get this problem sorted. Just need part numbers/ Brands for shocks if possible. Yes I have tried searching and I am having no luck. Thanks.
  • 3 months later...
Hmm, I have the 260rs stagea, with hicas, the guy at the import parts place says the r33gtr coilovers bolt right in to this car... Any truth to this? It's scheduled to be done in about 10 days.. If I need to rush other parts.. Hope I have enough time.
The front should be fine, but the rears are different and you'll also need to account for the extra ~300kgs a Stagea has over a Skyline.
Ring JustJap and get a set of BC's or similar. Once you tell them it's a 260RS, they'll tell you what's available and if they have other options.
Hey fellas trawled the thread but just confirming, I'm after rear shocks for my 97 rs4. Just standard shocks not looking to go coil overs, I see r33 rear shocks fit but are not really recommended. Are there any stagea specific replacement rear shocks about? I'm having no luck!
Cheers
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
