I'm not sure if anyone else has seen this, but Greenline have a list of 4 different suspension setups designed for Stagea. Here's the page, they start from AU$2000 down to AU$900. check it out guys if you haven't already. looks like i'll be giving these guys a call in the near future.
http://www.greenline.jp/catalogue/bccatpar...gory=suspension
Spoke to Heasmans, very helpful dudes
It seems that there are "genuine" Bilsteins for the Stagea, that Bilstein put in their catalog
ie
Front B46-2590
Rear B46-2589
but these are harder to get, and are a bit softer
the others that fit, are bit firmer and easily in stock are
R33 GTR front (B46-2107)
GTST Rears (B46-1916)
Hope this helps people
PS I spoke to Travers Wood at Bilstein Racing, free plug, good guy
What sort of prices would be attached to the Bilsteins?
email to [email protected]
but he quoted F $627 & R $453, which is about $300 cheaper than the
quote i got on the konis (tell him I sent you :)
They will also machine in the grooves for the C Clips for $15/groove (I assume that
means $60 for the set).
Wow Michael - I reckon that info is the best Stagea info on the forums yet! SK let us in on grooving the bilsteins to lower ride height using stock springs - but when i checked with my insurance company they said self-machined grooves would void any claim where the car was in motion as suspension is considered a critical component and any non-manufactured shock absorber changes would void a claim instantly (like bald tyres). BUT if they are done by Bilstein themselves then this would get around that problem! THANKS
:P
:P
Your kidding right? How the hell would an insurance assessor be able to tell who machined the grooves? He wouldn't even be able to see them unless pulled the shocks out. And they sure as hell don't do that, they aren't allowed to "work" on the car. You could mount the same argument with the nuts that hold the shocks in, were they done up by Bilstein? Then there is the wheel nut argument? Circlips, bolts, nuts, screws they are all fasteners, so the same rules apply.
:cheers:
I am with SK on this one, but of course if you lower the car 4 inches and have 5 degrees of negative camber on the rears, dont expect anybody to cover you, it wouldn't matter who did the machining on the shocks.
Like all insurance stuff, full disclosure is the safest (they will use ANY EXCUSE to get out of paying). I would have thought that a mod that is done by a suitably qualified person and still is able to get a RWC is ok.
I shopped around for insurance for a while and got a pretty good deal with Just Cars. NONE of the "normal insurance " companies (AAMI, RACV etc...) would touch a grey import anyway. So just talk to them. There is no doubt that ANY MODs will give a increase in premium, but as long as they are legal and if needed engineered, it should be ok. Thats just life with modded cars and "esoterica".
cheers
Hmmm - maybe this guy was having me on - but he seemed pretty sure - like hed had the query before - talked alot about how 'doing it yourself' you may compromise the shock by grooving too deep etc. He said there were only a few critical insurance voiders in motion crashes - including non-legal tyre wear etc - and also shock absorbers - one of those things in your insurance 'full' contract - all that fine print you sign off on where it says stuff like "I declare that the vehicle has roadworthy tyres and dadada and understand that not having roadworthy tyres or parts used other than as the manufacturer intended dadada will void any associated claim for ...." Of course he said if you rear end someone and have $2000 of front bumper work no assessor is going to check your shocks and ask about your circlip grooves! lol BUT he said if you happened to wipe out another car and a family then they'll be going over the wreck with a fine-tooth comb to find blame... so yeah when they find modified shock absorbers that is against the conditions of insurance (that bloody fine print long 20 page booklet) and your signed declaration was misleading therefore voiding your policy. However if you can prove they were manufacturer intended modifications (ie they did it and you can prove it eg receipt) to the shocks then you are ok.
Anyway - could all be some guys version of having fun at work and making life hard for me - but i WILL dig out the insurance terms and conditions booklet and go over the fine print... not that itll matter now that Bilstein machine the circlip grooves themselves. Eitehr way - id love to prove the guy wrong - but to save any doubts it great to know Bilstein do it anyways.
:P
Another suspension option with specific fitment for Stageas has been added to the Nengun site... ZEAL coilovers... dont know much about them - in fact never heard of them... but another option none-the-less for anyone with with a spare $2200 :)
http://www.nengun.com/catalogue/product/384
It states the spring rate - but I have no clue about interpreting spring rates... maybe SK can put it into laymans terms as to what sort of ride thats likely to give??
Oh yeah - and they're yellow - will match my Stag woohoo lol
They state 7/6 which is 7 kg / mm (390 lbs per inch) for the front and 6 kg / mm for the rear (335 lbs per inch). As a comparison, the standard Stagea fronts are 165 lbs per inch, so that's a 137% increase in spring rate. Usually for sporty road use I would be loooking for around 30% increase. I think I'll leave it at that, you can make your own judgement from the numbers:cheers:
OK - so a dam hard ride LOL :D
Hard is not good on Ausie roads. The Teni's in mine are way to hard. I bounce and bang around on every bump, get air bourn on bigger bumps and almost get thrown off the road on mid corner bumps.
I had trouble keeping up with an old Patrol on a narrow windy bumpy road today and felt like I was going to be pinged of the road a few times.
(The Patrol was flying and getting loose on almost every corner)
The first thing I will be doing when I sell my Skyline is putting in a set of Bilstines with GTR front springs and specially wound Whiteline springs for the rear
  • 4 weeks later...
I keep forgetting to post it up, the rear spring rate is 170 lbs per inch. As previously posted the front is 165 lbs per inch. Considering the weight carrying capacity of a waggon, that's not surprising.:D
Hey guys, i got my suspension i ordered through nengun today, the TEIN type wagon. only problem was when i opened the box, there were only 3 shock absorbers, the 2 fronts and only 1 rear.
I think this is a funny sort of suspension kit, considering what i paid for it.
as soon as they send me the other shock absorber i'll let you guys know how it fits, for now here's a pic of the 3 i have.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. 😭
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
