  • 3 months later...
  • 1 month later...
  • 2 months later...
Hi guys,
When I imported our 250t RS4 I needed new shocks all round so stupidly bought the cheaper BC set instead of the BR. Now they are stuffed and our use for the car has changed a little. I wonder if anyone knows whether you can fit the RX suspension to the 250t rs4 and lift the ride height? Anyone have any experience importing stock suspension direct from Nissan Japan? Or know if you can do that via local Nissan dealers?
  • 3 months later...
2 minutes ago, Long and low said:
I have a set of BC gold adjustables to go in. Seems pretty straight forward to put in. I'll be doing it in my garage on my own.
Thanks for that. I'm only doing the springs so expect to need a spring compressor. Bought them after a couple too many, now have to work out how to do it ??
If the fronts are anything like a PNM35 ('04+) then you better have hands like a Geisha girl to get out one of the left-side strut top mount bolts. It sits under an A/C pipe so expect to use some inappropriate language.
Other than that, pretty simple stuff. I had to do the rears but from pictures I've seen it'll be easier than the front.
The stock springs are pretty stout and ate one of my spring compressors because I didn't get enough coils in between the jaws, so try to get as many coils as you can between them.
Thanx for that.
  • 2 years later...
I have a rear upper ball joint with play and want to replace the whole arm instead of paying $500 for new genuine Nissan part will the arm in a 2005 rx350 bolt straight into the 2004 ar-x Four model as well as the lower control arms. Been measuring and comparing photos still stumped the shocks fit perfectly everything seems to match up but the fact it's rwd has me 2nd guessing does anyone know?
Have a look here it will tell you the part numbers and you can see if they match.
https://nissan.epc-data.com/stagea/
  • Like 1
  • 3 years later...
Are people still active on here? Never used this site before so forgive me if I’m going about it the wrong way.
wondering if anybody else has encountered issues with rim to rear suspension clearance, and has any remedies or ways around it that don’t involve beating the guards or smaller width rims.
picture attached (is terrible I know) is of backside of rim barrel and coil over, can basically just fit a finger in between, which is fine on anything that is flat. But anything where the front and rear are hitting opposing angles the rims rub on the coilovers which is seriously unpleasant. Can’t run any less camber or the tyre rubs on the inner guard to much, and don’t really want to lift it up high enough to get more clearance off the coilovers
appreciate any pointers cheers!
23 hours ago, RBW49N said:
Is it an rs4 or an rs4s?
tou can fit an S14/5 rear subframe and suitable driveshafts if it is a factory auto and it will give more clearance
Rwd, factory auto, would that alter where the wheels sit? Track width etc or just where suspension bolts up?
It will alter the track of the car and enable you to run less camber without hitting the outer guard and give the coil over clearance
6 minutes ago, Yeevez said:
19x9 +30 I think in the back, not to aggressive really
weird, I have standard r34 GTR wheels (18x9 +30) on my factory auto and they fit perfect inside and out
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
