Hey guys, i got my suspension i ordered through nengun today, the TEIN type wagon. only problem was when i opened the box, there were only 3 shock absorbers, the 2 fronts and only 1 rear.
I think this is a funny sort of suspension kit, considering what i paid for it.
as soon as they send me the other shock absorber i'll let you guys know how it fits, for now here's a pic of the 3 i have.
Post up the measurements (wire ID, coil ID and the number of coils) and I will work out the spring rate for you:cheers:
Well Nengun say they sent the 4th shock in a previous package, but with the same EMS number. My post office said they haven't received another package with that number, so idon't know where it is. hopefully it'll show up somewhere, it has my name and address on it, that should help it find me.
So they sent a single shocky first by itself, then sent 3 more... LOL - wtf??
Posted this elsewhere but should probably go in the suspension thread for people looking only in here for supension options...
Here's an dam expensive choice at $3700 - but very noice being PentRoof Bilstein WGNC34 specific coil-overs :D
order online from: http://www.ab-flug.co.jp/indexf.htm
(and shout me a set while you're at it)
Here's an dam expensive choice at $3700 - but very noice being PentRoof Bilstein WGNC34 specific coil-overs :cheers:
They won't fit a Stagea (non 260RS), they have forks at the bottom of the rear shocks, Stagea rear shocks have eyes at the bottom. They are GTR shocks I would say.:)
Awww - dammit
Thanks SK... spoilsport
Do all the parts on my other thread look like 260RS only parts SK??
Cheers
They state 7/6 which is 7 kg / mm (390 lbs per inch) for the front and 6 kg / mm for the rear (335 lbs per inch).  As a comparison, the standard Stagea fronts are 165 lbs per inch, so that's a 137% increase in spring rate.  Usually for sporty road use I would be loooking for around 30% increase.  I think I'll leave it at that, you can make your own judgement from the numbers:cheers:
Call me stupid SK - but I cant get my head around this - didnt really think about it when you did this reply above, but...
If 7/6 is around a 137% increase and way too hard, and 30% increase is ideal ... arent the Tein S Tech springs ok, being 3.1 Front (172pounds/inch or 4% increase over stock) and 3.8 Rear (213pnds/inch or 25% over stock).
The Tein S Tech lowering springs would end up under the 30% max you recommended, with 25% increase at the rear, and pretty much same stiffness at front with only a 4% increase.... but you have said before the Tein spring are way too stiff.... am I still missing something in all this suspension mumbo jumbo??? :confused:
Cheers
Hello all (esp SK)
Time to replace the radius rod bushes on the stag. Do I go factory or
do I go whiteline ?? if they have them
And while I'm at it, should I get a more "adjustable" setup in the radius
rod setup ??
Any hints clues would be appreciated
cheers all, and thanks, this is a great forum !!
Cheers
Nope, you got it right, if the Tein S Tech are truly 3.1/3.8. Maybe they started to listen to the rest of the world. Then it's down to what shock valving rates they are using.
Hello all (esp SK)
rod setup ??
Stageas (like GTR's) need more caster real bad, so I would always go for the adjustable Whiteline replacement bushes. Being 4wd, we can't get as much caster on them as GTST's, but every little bit helps.
Looking for some input guys (esp SK).
Getting the radius rods replaced (bushes are shot) on Wed, and the guy said I can have the adjustable versions if I want. Is this a better option than the whiteline bushes (both will give caster adjustment ??). Or do I completely misunderstand
the Stagea front suspension ?
thanks and cheers
thanks and cheers
Previous post on this subject......
In order to increase the caster you simply pull the front wheels forward in the guards. Not enough to rub though. This changes the front steering toe angles and therefore you need to re-align it after fitting and adjusting the caster.
If the caster rods you are looking at have spherical joints at the front (not polyurethane or rubber) then you will notice a slight increase in NVH as there is no dampening. Sphericals also wear rapidly on Australian (rough) roads, and they then knock noticeably.
Since they don't have as much "play" as a polyurethane bush they do provide more constant caster settings (less flex) but that comes at the price as above ie; as usual, you don't get something for nothing.
As you can tell, I am not a fan of sphericals in a road car, they wear out very fast in that environment, knock like a bustard and cost as much as a new arm to replace. Plus they add quite a bit to the NVH (noise, vibration & harshness) even when new. Consequently I would always recommend an adjustable polyurethane bush.
:rofl:
SK, your'e a legend, thanks heaps for the info.
Just to let people know, i'm getting my TEIN Type wagon coil overs and whiteline sway bars installed tomorrow, i'll get some pics up once i get her home. i don't have time or tools to do it myself, which is a bummer because this thread is super helpful.
anywho, just letting people know if they're interested
Cool, it'll be good to see how it goes. Once done you'll be able to out handle most cars :D
I've been tempted to get a set of sway bars, but I know if i get them then I'll want new suspension and then do the camber and next thing i know I'll get a loan and do a rb26 and 5 speed converstion.. lol
Well got my car back from Inline. he says the springs have to settle before he can lower it at all, but the sway bars are in and work absolutely awesome. the car takes corners like it wasn't even trying, and there's barely any body roll. all in all a good investment in my opinion.
The Bilsteins go in this weekend, so I measured the centre of wheel to guard heights as it is now;
RHS Front 395mm
RHS Rear 370 mm
LHS Front 395mm
LHS Rear 372 mm
I am thinking of around 360 rear and 370 front, so I will have to machine some extra circlip grooves.  Maybe 6  at  5mm intervals.
Need some feedback from the guys that have already lowered theirs, please post up your centre of wheel to guard heights...........:cheers:
SK,
I realise this is an old post but have just measured the S2, and the figures are:
RHF 360mm,
LHF 360mm,
RHR 365mm, and
LHR 372mm.
However I have a weeping shock on LHR so may be this is having an impact on height.
The vehicle has NISMO springs but have no idea as to what the specs are.
Marc2
SK,
RHF 360mm,
LHF 360mm,
RHR 365mm, and
LHR 372mm.
Marc2
Thanks Marc, looks like the usual 30 mm lowering on the front, but with standard height rear. I did similar with ours, it takes away that nose up look they have when the rear springs settle due to load carrying. The diff right/left rear is usually because they spend a lot of their life with just the driver in the car. If you are changing shocks it may pay to check the free height of the springs and maybe swap left to right.:cheers:
PS; send me the spring specs and I can rate them if you like, using the computer spring rate simulator, it is very accurate. I would need the wire diameter, coil ID and number of coils.
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
