HI guys :D
i've been looking for this thread, but it seems that it doesnt even exsist!
all car forumes has one -if not a few- threads about it, so i thought we should give it a go..
please every one chip in.. starting with the FREE waight reduction...
keep in mind that most of us aren't welling to go extreme (like ditching the AC, stereo,..etc) so keep it streetable! :burnout:
https://www.sau.com.au/forums/topic/53116-waight-reduction/
there is an old thread with the weight of most of the components for an r33.. http://www.skylinesaustralia.com/forums/sh...ead.php?t=28670
realistically though you may save 100-150kg.. but it would make the car very primitive for day to day driving... and most of the time you can upgrade the power to overcome the weight (again been discussed in other threads)
i ripped out most of the interior of my old shitter r31 a few weeks ago, but the noise levels were too annoying and it didn't feel any noticeable quicker so i put it all back in :)
if you want to spend $1000's saving 20-30kg here, another 10kg there on CF, go for it.. I'd rather spend the money on upping the power and/or handling and keeping a nice car, than worrying about it too much unless it was an exclusive or 90% track car.
https://www.sau.com.au/forums/topic/53116-waight-reduction/#findComment-1043812
there's not a whole lot u can do for free unless u want to take seats and trims out, get a bar to lock out the hicas, saves aboutr 20kgs i think
if u wanted to go crazy then u could go cutting things, but then it wouldn't be street legal anymore
is there a step by step guide on removing hicas ??
https://www.sau.com.au/forums/topic/53116-waight-reduction/#findComment-1043846
also, my heater is desconnected..
-since am going to need it when hell freezes over!:)-
so should i go ahead and remove the whole darn thing?? is it easy? and how much waight do you think it is...
what about the engine bay?? nothing to get rid off over there??
https://www.sau.com.au/forums/topic/53116-waight-reduction/#findComment-1043851
how do u mean the heater iis disconnected? isn't it all one system?
u could take the reinforcements off the front and rear bars, but wouldn't recommend as would minimise crash zone, don't think theres much in the engine bay, but i agree with predator, power is so easy in skylines y not just buy go fast bits
https://www.sau.com.au/forums/topic/53116-waight-reduction/#findComment-1043870
for some fun, strip the tar out, about 15-20kg around the car there
and of course the air con with its compressor, receiver/collector, heat exchanger. Heater core in the dash as well if you are kken.
https://www.sau.com.au/forums/topic/53116-waight-reduction/#findComment-1043928
replace non critical bolts and nuts with alloy or alluminium one's. Any bolts which protrude from the nut can be cut down. remove the tar from under the floor pan (may induce rust)...
Brackets like the one that holds the Fuel Vapor canaster can be modified. there over kill. Look around under the bonnet see what else can be cut down..
Ummm use helium in your tyres :)
https://www.sau.com.au/forums/topic/53116-waight-reduction/#findComment-1043930
relocate the battery to the boot so theres more weight over rear wheels. your not losing the weight but at lest it's more useful their. prob no point in a gtr being 4wd.
And no point in a R33 or R34 because the battery is already in the boot. Yes, Japanese cars are always superior :)
https://www.sau.com.au/forums/topic/53116-waight-reduction/#findComment-1043986
lol! Like any of our cars are street legal by the RTA's rules anyway!!! hahah Seriously, it would probably only have to be about 3% of users on this site which have a skyline which would pretty much have to be stock in Every way to be legal by the RTA's modding rules.
https://www.sau.com.au/forums/topic/53116-waight-reduction/#findComment-1043989
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
