That is a massive difference.
I think 272s would kill the idle a little too much for my liking.
SK,
Do you think the 260s would be better than the 256/260 for my application? I think I will drop in a set of cams and keep the GT-RSs for now. If it doesn't work out, the cams won't be wasted with smaller turbines anyway.
I have attatched the GTRS graph from the HKS website. I would love to know what has been done to that engine, because it looks like the engine is making 1.8kg boost at about 5000RPM. I guess the Jap fuel helps because you can run heaps of timing on spoolup.
Is the R34 RB26 a bit better than the R33 version? Or is the extra torque on the R34 over the R33 just due to ECU mapping?
The R34 GTT RB25DET Neo has solid followers, so Tomei have 260 degree Poncams for them. The 256's are for the R33 GTST R25DET (non Neo) which has hydraulic followers.
As for the HKS dyno, I have yet to hear of anyone, anywhere in the world that has achieved that result. I don't know what HKS did on the engine dyno, but this is what I would do;
1. Run a highly oxygenated fuel with a high RON, like TurboMax (sold as HKS Drag Fuel in Japan) :idea:
2. Use a water to air intercooler with iced water :aroused:
3. Who cares about detonation, it only has to do one run
4. Don't worry about tuning for daily life, just screw everything up to the max.
5. Use a constant loss water cooling system (not a radiator) and maintain the perfect engine temp
6. No flywheel, alternator or water pump
7. Run the turbo inlet off the dyno room airconditioner outlet, with no restrictions
8. No exhaust, mufflers or restrictive pipe, straight off the tubo dumps into huge vacuum assited ducting
This would give me a "true" result, but hardly what I would call "real world". But maybe I am just more devious than HKS. :rolleyes:
Yeah...I see your point :D
Just a bit of an update, with more road tuning, I now reach 1.3 bar boost by about 5400RPM in third gear. The car feels much better to drive. If cams improve the midrange even slightly, the driveablility will be good enough for me.
The only thing is, I will definately need to fix my AFM issue first.
Mik,
im running standard BNR34 N1 bottom end and BNR34 N1 turbos in my 32. I also have trust 264 9.1mm camshafts and the car is making more power than your car and is making full boost by 4750 rpm. There is something funky going on.
TG
rev210: do you actually know of anyone that can source a C/F prop for an RB26?
LW.
These guys can do one for you.
http://www.ctgltd.co.uk/motorsport.php
Or these guys...(probably better since the Dollar conversion works better for us).
Ask them about a group buy discount.
http://www.acpt.com/
    • So many people don't notice it, as batteries decay slowly over time. Two big reasons people end up noticing and needing to replace batteries: 1) The cold weather. The cold not only makes it harder to turn the engine for a few reasons, but it also increases the batteries internal resistance. So this means you need MORE power to turn a colder engine, AND the battery has a lower limit on how much current it can provide. 2) Something gets modified/altered/added in the wiring, typically an aftermarket accessory, like a dash camera, or an alarm etc, and this adds a small amount extra onto the battery, and pushes it over the edge in its failing days. But if you hadn't have read this thread, and just pushed through, chances are you might have made it through this winter, just. But come next winter, it would have been kapoot. But the fact you changed it out now, means you've instantly noticed how much nicer it is for starting, and will be less worry for you that the engine won't start now.
    • Holy shit, I'm glad you brought up the battery issue and I'm glad I asked about measuring it. Old battery was at a healthy 12.82V in the morning with the car turned off. Removed the fuel pump fuse, clamped the multimeter on at min/max/average and cranked for ~3 seconds. It dropped down to 8.30V. So yeah, not surprising it struggled that much. Picked up a fresh battery from supercheap and it's ridiculous. Haven't done a cold start yet, but man, even with a warm start the difference is night and day. I can't believe I lived with this for so long. Just blamed it on it being an old modified car. Went with Century because convenient. If they are shit it'll be a future me problem. But just in case I set up a reminder for 30 months - 8 weeks to check on the battery state and get a warranty replacement if necessary.
    • There's another sensor that sits inside the evaporator, that's a C U N T to get to, but can be done without removing the entire unit. Usually it's not the sensor that dies but the actual capacitor in the circuit (part of the plug that dies).
    • Putting the climate control CU into diagnostic mode is independent of the ECU. You just have to do the dance prescribed in the manual. No, I do not know what the dance is. I have an R32, so use the dance in the R32 manual. On older cars, I would have said "no, the ECU should not affect whether the A/C works".... but for an R34 that might be wrong. I don't recall the detail, but there was extra mods required to make my R32 A/C work against the R34 ECU. The R34 ECU apparently gets involved in the running of the A/C more than earlier cars did. Theoretically, if the PFC is a true plug in, then it should just work the way that the original ECU does - wrt A/C. But there's always scope for them to have not cared. Nope. Pressure switch out = getting the fridgey out to pump the gas out before pulling the switch. The switch really cannot sense gas pressure unless it is up against the gas.
