Ok,
I have a R32 RB26DETT in my Cefiro, I use this on the street but mainly on the track in Drift Competitions.
I want this engine to be reliable, so have planned to spend a little bit of money to do the following mods, whats your thoughts, and anything else I should think of.
The engines ideal state will be around 450RWHP which is shit loads really, but hey why not. this is in the future with suitable turbos, computer, etc.
BUT FOR NOW:
I am going to pull engine down.
Get the Rods balanced, shot peened and new ARP rod bolts fitted.
Remove standard Oil Pump? (not sure if this is necessary for dry sump setup)
Install external 3-4(unsure of what is needed) stage oil pump, oil canister, remote filter, large oil cooler,
Modify standard sump for scavenging returns
Oil feed restrictor in block to prevent flooding of cam areas.
Change aloy plugs in crankshaft with cap screws (i heard they can fall out with high pressure oil pump)
Use standard gasket set, or aftermarket gasket set(tomei?) any point going tomei?
Is there anything important that i should know in regards to dry sumping the engine, anyone that has done this, i would be interested to know the plumbing side of it, i know how the dry sump works but actual real life plumbing of the rb26 would be helpful.
If bearings and rings are in good nick i will leave them alone.
With these basic mods, what power should i be able to support all day long?
Any help appreciated.
Thanks
Dayna
Hi Dayna, dry sumping adds complexity and is not cheap, plus there are some convenience issues. Usually for good weight distrubution you would put the tank in the boot and run the lines though the cabin, as underneath is asking for them to get hit. The breather tank would also normally go in the boot as you have to vent the dry sump tank as would an oil filter. Add that to the fuel system plumbing and this makes the boot unuseable for carrying anything, even the spare wheel can be a hassle.
We have raced Skylines for a number of years and found a good winged and baffled sump to be very very effective in preventing oil surge. We have on board data logging in the race cars and I have never seen any evidence of oil surge, and we pull some serious lateral G's.
I have looked at a lot of very serious drift cars and haven't seen any with a dry sump system. Not saying that there aren't any, just that I haven't seen them.
For your purposes, personally I think dry sumping is an overkill. Get a good winged and baffled sump and use the saved money on other things to improve the competitive performance.:)
taking up boot space wouldn't worry me, i don't use the boot. Its pretty much a drift car, thats road legal.
Well, lets look at some costings that i've come across so far.
To Fix the r32 crank collar issue will cost me $550
for a good oil cooler kit will cost me $550
How much for a baffled sump setup? $400?,
best to make my own? or buy an off the shelf aftermarket one? I don't want to extend the sump lower than it is for ground clearance reasons.
uprated standard placement fit oil pump $1750!! !NEW
TOTAL standard internal option setup = $3250
lets compare to a dry sump setup.
? stage pump complete setup $1500 s/h sourced from USA
oil cooler $250
Adapters (oil filter, remote adapter) $200
Oil Lines $200
obviously would cost a bit more to run lines to the rear of vehicle if i did do this.
sump mods $200 (guessing)
DRY SUMP TOTAL = $2150 + $500 over budget
It seems to me cheaper to sort out a dry sump system, and superior in some ways, i know it seems an over kill, but cost wise, why not?
are you saying i can get away with the standard r32 oil pump? that would save $$$ but still be very close priced to the dry sump setup, and being that the dry sump setup would have better oil pressure etc..
sure money is always an issue and i would like to save hassle and money. but would also like to be cost effect that i am getting the best bang for my buck. and if the dry sump cost a few hundred more, i thought it would make sense to go this way.
A good mechanic friend of mine pointed me towards the dry sump option, as he landed in NZ a complete setup for his V8 drag car for $1200, pump, tank, lines, earl fittings from USA (second hand)
thats the info in front of me at the moment.....
Dayna
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
