FOR SALE: T78 :D Just Kidding
OK... it's not the best turb on the market but I just got the car and it's got this set up and I enjoy it for now. Never been for a ride in twin set-up.... never been in any other GTR besides mine (so I have no reference ponts to make judgment) I think I will shut up now and keep my NOOB comments to myself.
siksII - day to day driving - yes I do change gear well B4 I hit the 8k mark.
  • Replies 43
i wasnt talking about when u drive to the shops every day :evil:
plus i was more referring to sydneykid's comment as he wouldnt be talking about day to day driving... my point was if the revs drop 3 grand when u change u would not have to wait for boost in a gtr if u shift at the standard redline
i have been in a stock one and one with n1's (runs 11.7) (both r33)
the stock one feels pretty slow not much fun there...
the other one has ridiculous amounts of torque power in the midrange from about half way through second gear...and feels like it could pull hard wayy past 8 grand. (stock rev limit set on pfc)
Maybe my Rb26 doesn't even make 150hp of boost, i couldn't really cares, it get around fine off boost and to quote whether u got race cars or what ever is shining the torch abit. I'm not out to prove i have massive technical knowledge or do i have a golden spanner. I'm just discussing my specific case. Just from my limitted knowledge of cars I know enought to say no 2 cars are exactly the same with exacting set up. So is everyone driving style.
But i can say one thing is, modifying cars is a very much so personal taste, and if u want to build a track special looks no further than some stock cars ei. from Porsche-bmw-lotus. As the amount of RD that went into these cars will humble just about most cars that are screw together by the hobyist racer, with out having one screw turn.
I have an open mind to alot of things said and respect alot of ppls opinion disregaring their technical knowledge, But it be more courteous to be discussing the relevant points, than having critical comments and quoting 3rd party "facts"
I'm sure lots of ppls here think i'm a no brainer, but that's life. So be it.
I have no problem with people having their own choice, after all it is their money, their time and effort. All I do is point out things that need to be understood when making a decision, too many people make decisions without the data to do so.
I may use race cars as an example because I have thousands of data samples to draw on. I don't have to guess, I have the data to back it up. Data for road cars is not such a priority, I have a lot but not anywhere near as much.
Road turbo sizing for me is very easy, I cruise at 120 kph max and as pointed out it is better to do that with no boost. My Skyline does 37 kph per thousand rpm in top gear. So I don't want any boost until after 3,250 rpm. So if I choose a turbo that will make boost at 3,500 rpm I will have the best of both worlds. I only have to rev it to 6,500 rpm in first, so it drops to 3,750 rpm in 2nd and I still have plenty of boost.
I don't understand, for a road car, anyone not wanting boost until 5,000 rpm, that's a 185kph cruising.
I should point out that there are plenty of other factors involved in when the turbo makes boost, many more than simply the tubo itself. Camshaft timing and lift, compression ratio, porting, manifolds, igntion timing, fuel tuning boost controller etc etc.
Hope that helps clarify:cheers:
    • Wanted to clean the film behind the triple gauge so the lights show through better.  Progress so far….
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
