Hey all
Well i have an R32 GTST and i just had my head rebuilt...
and the bottom end is about to be rebuilt..
but i dont really know what with yet..
Basically i have 3 points i want to fulfil
1. 220 - 250rwkw. no more no less ;)
2. Reliability
3. Response
I have a 3 1/2 inch cat back exhaust. Greddy EBC, HKS pod, and Apexi PowerFC
Now this car is always going to be my daily street driven car. so i dont want anything too resiculous. therefore i would be more than happy with 220.
but as it is my daily drive it needs to be reliable. and i want response :P
I have been quoted 3k for the bottom end to be done. that includes balanced and linished crank. stock rods, all new bearings and all. and some Arias (spelling?) 20thou oversize forged pistons.
down the track i want a cooler, finish my exhaust (from turbo to cat), and a better turbo. i dont know whether to hi flow or get a newy, i will get some 13bt injectors, and a fuel pump and reg. Also some Rb26 Cams would be good with some adjustable cam gears :)
overall budget is a problem.. things need to be relatively on the cheap side. though i dont want to do anything too half assed..
What can anyone recommend? what should i do to the bottom end? are forgies overkill? or will i need them for reliability? what turbo should i get for 220kw with response? would a hi-flow turbo be enough?
Any help appreciated. Thanks guys.
p.s Yes i did do a search and didnt really find anything that help about the forged pistons etc.. so i thought i would post it all up.. Thanks again :)
https://www.sau.com.au/forums/topic/53193-i-have-no-idea-what-to-do/
Forgies will depend on future mods, but if your aiming for 220kw at the wheels then if the motor is relativley healthy that should be no problem, i know quite a few R32 GTsT's running 20psi and making well over 220rwkW..
I would do the cooler and exhaust first. No point in continuing to allow the engine to ingest hotter-than-necessary air. And no point in choking the performance by not having the exhaust gasses able to easily escape the turbo housing. Then the fuel pump - no point in risking that 3k bottom end on a lean-out from a crappy pump.
My understanding is that the forgies will be a bit of overkill - the stock Nissan items can handle the power you are looking for (I think that info is available thru a search)
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 馃槢   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
    • Oh nah, S55 doesn't eat bearings, just the crank hub slips lol.
    • When鈥檚 the tow ball on the 33 coming? 馃檭
    • I welcome any basic question that can help haha. Yes it has 2 unis but the driveshaft is a one piece and the unis are welded without a slip yoke at each end.   What's funny is anytime I've ever had wheel vibrations it's always been in the front so I automatically assume it will lead to steering wheel shake and not chassis vibration. With that being said, I never considered looking at my rear wheel balance... I have doubts though as this wasn't an issue before I pulled the motor and trans but is still very much worth a look. I'll do that tonight after work. Thanks.
