Just had to post something on this.
Couple of weeks ago, I visited Evo R in search of a GTR ignit key, I know it's just a key, but I wanted one. So turned out it would cost $120 and take three weeks coming from Japan. So I picked myself up off the floor and left.
I was recently back as Evo R to find that it now costs $140 with the same wait. Stood up again and walked out.
So I called Nissan who said that they could get one, it was $41 something and was silver in colour. Figured it couldn't be too bad so said to get me one. Came in the next working day and picked it up today. IT"S THE SAME KEY!!!! The one Evo was trying to flog for $140.00!!!
So now I'm so pleased with myself, and if any fellow GTR owners are interested, $41.39 through Nissan.
Photo attached. I know, it's just a key. But I like it.
https://www.sau.com.au/forums/topic/5320-gtr-ignition-key/
Yeah, bit bigger than I would have chosen, but it was already in the car so.......
It's a Boomerang Alpha something, it's a two way tranceiver meaning you not only send a lock/unlock command to the car, but should someone breach the security, it will actually page you by beeping and vibrating as long as the car is within a 1.2 km range. Mine seems to be more like 150m though.
https://www.sau.com.au/forums/topic/5320-gtr-ignition-key/#findComment-81253
Originally posted by Gumby
I think the key profile for a GTS-T is the same, you can actually buy the same key with Nismo on it instead of GTR.  But don't think you'll get it through Nissan.  Evo R has the Nismo version on display.
You should be able to get the Nismo key from Nissan. The guy at the local Nissan dealer did me a second GTR key for 40bucks too & if your key has a serial number on it they can cut it at the same time:D & it should suit all Skylines.
https://www.sau.com.au/forums/topic/5320-gtr-ignition-key/#findComment-81333
For those wondering about the alpha, I don't know what they're worth as the unit was already installed in the car when I bought it. I believe they are available from 'In Car Options' in Melbourne, search the web and it should list some other dealers.
Basically, the pager uses the same transmission signal as the alarm notification, that is, it only communicates on its own discrete RF frequency. There is a little module stuck on the inside of the windscreen which reads "tap to page", and tapping the spot triggers my handheld which alerts me and says "CALL!" So no, I don't actually pay anything.
Don't know a great deal about the unit as a user manual was not supplied. I do know it does some of the following.
As well as all the normal functions of a remote alarm:
- Alerts transmitter of alarm trigger up to around a km
- Automatically starts engine on programmed time.
- Provides Cabin Temp from transmitter
- Remote engine start
(The idea of the above two is that should you check remotely that the cabin temp is too cold, you can remote start the engine and the CC warms the cabin to desired temp.
- Two stage shock alert back to handunit
- Proximity disarm (it actually senses the remote is within proximity say 2 metres and auto unlocks the doors without having to push the button)
- Also doubles as a turbo timer which bases the run on time on measured oil temp and revs. When I've been taking it easy, it doesn't run on, when I've been thrashing, it does.
- Remote engine off, ie. if the unit runs the unit on and I've removed the key and am no longer in the car, the Engine button can be used to remotely stop engine and arm.
- Does quite a few other things which I have yet to use
Don't know how good it is as a deterent, but it looks serious with the driver paging module under the screen and long range receiver device under the visor.
No ones attemped to break in as yet. (TWood)
https://www.sau.com.au/forums/topic/5320-gtr-ignition-key/#findComment-81900
Guest Boxhead
not trying to deter you guys from that alarm, it sounds good, but, from what i hear it aint cheap, and i know dAVE on this forum is actually doing, or did a group buy for a similar alarm, and it worked out cheaper, i am not sure of exact details, but here is his email address for you, honestly, check the one he is getting out before you buy anything...
[email protected]
https://www.sau.com.au/forums/topic/5320-gtr-ignition-key/#findComment-81921
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
