Pretty certain the second cable quadrant is for criuse control not TPS . I have never seen an FJ20 std with a flex plate on it yet .
You maybe right about the cruise control.The car was an DR30 RSX with n/a FJ,auto,cruise,power windows,mirrors etc etc
Ive still got the auto box but it soon tired when i put my turbo donk in front of it.
There is nothing very exciting about these switches . I had one in bits years ago and all they have is a dual contacts for open and closed throttle . The vane type air flow meter does the rest . The genuine MR30 manual shows you how to set it .
Thats the whole drama here mate, the wolf doesn't read the standard TPS, just because it is only an on/off switch basically, i need a true TPS for the wolf to work on my motor!!
Adam you should be able to get away with running 14psi through your motor, Josh was running that and his was only just starting to lean out really high in the rev's, so if worse comes to worse get a malpassi or something and wind a touch more base pressure into it!! Do it all on the dyno though :)
And Joshs died didnt it
Yeah Josh's died from a injector that was blocked last time i heard from him...Like i said if your that worried get a malpassi and stick it on the dyno and get them to wind a touch more base pressure into it so it doesn't lean out up top....
BTW my car runs now :) Started her up sunday night, getting wheel spacers today for it and it should be able to move under its own steam for the first time in over 12 months :D :D
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
