hey guys
Must sell this alarm for a bit of cash. BRAND NEW , Still in box....
This units features include:
2-way responder remote
Remote keyless start
Built in turbo timer
Power door locks relay
Power boot lock relay
Panic button / Vehicle locator
Revenger six tone siren
All info here
http://www.drdetailshop.com/V791XV.htm
AS u can see it retails for alot...over 800aus
PRice is 600 firm....if ur seriously imterested pm me here or ring 0421 928 851
Thanx
This was purchased from qld about 1 month ago. It was pretty much an instinct buy as the person was selling it for rather cheap, as he was going overseas. I thought it would be cool, and i still do, but just payed for insurance last week which was alot more than i had expected and with the holidays i am completely broke
    • I'm guessing you mean something like this size? https://www.supercheapauto.com.au/p/bodyworx-bodyworx-hard-soft-sanding-block---70-x-135mm/594184.html?cgid=SCA01100303#srsltid=AfmBOoq_qZTEe3boann9BaHiB2f59dxJlosWLzCr0zm_weHgUlDX-N5f&start=6 Are they sanded completely flat?
    • Just a standard sanding block size. With the rock chipa they are quite small. I sanded them as you could feel the edges.
    • Say you've just laid all your filler and your about to start sanding, how large is the sanding block your using?  Like a high fill primer? Technically possible but would be a nightmare. Just guessing from the photo, but they look small enough that you might get away with using a 1k spot putty. Normally you'd use something like this on pinholes but with the type of project you're working on I'd give it a go.
    • Omg Brake pedal removal.. FML!!
    • I mean, I can confirm the TPS is at 100%.... I can confirm when we installed the TB and setup the cable that the TB was indeed fully open at max pedal travel.. the same 'curve' (WRT MAP vs MAP) existed with the previous setup/TB/manifold as well... No, we did not do a run with no intake connected. I would love to go back in time to do such a run to rule out the intake. It would have also been good to do a run with the airbox lid off. There's a test there where increased IAT vs more available air could be a positive tradeoff. I remember taking the lid off my R34 Turbo setup back in the day and noticing a monster increase, even if IAT's did go up. Could be similar. Hard to test unless I find a very deserted road.
