hi there i had ma R33 GTS-T 1994 for about 8 months now and im looking to get some basic mods and tuning
im looking at purchasing
600x300x76 FMIC
3 inch dump pipe and hi flow cat
Power FC and tuneing
runnin around 10-12 psi
with these mods wat could i expect with power output say on the rear wheels
the skyline is 186 kw at the engine and i carnt rember how much it is at the wheels in stock form..but wat would i expect with these mods
would i be able to obtain 200kw @the wheels or no
also wat else would i need to upgrade ?
fuel pump ?
injectors ?
rember i still want to be able to drive this car to work still
and what 1/4 mile times would i be looking at ? with these upgrades ?
https://www.sau.com.au/forums/topic/53272-which-basic-upgradespoweroutput/
Well if all done right and tuned at 12psi, a high 12 could be on the cards.  Ive got similar mods but no Power FC, only a SAFC and i ran a 12.98.
It all makes fun as a better daily driver to work.
hmm thats cool but how about power output ?? with those mods
ive got all the mods u mentioned 'TiNTiN' and i made 195rwkw on 12psi which drops off very quickly to 10psi, on the ICE Performance Dyno and i can tell u that the car is ten times better than when it was standard... the response and pick up it now has is fantastic for a street car, especially in the low rev range. it really pulls hard, ill be running at calder soon but ive been told that it is 'capable' of a very low 13...
u wont need to upgrade the fuel pump of injectors until u install a bigger turbo...
I would definatley recommend u go down and see the fuys at ICE..
ok seeeing that i get all these mods which will be likely
i heard that gettin adjustable cam gears can also help
are the required and how much do they cost ??
also if i get a full power fc tune at 12psi for max power output
wat happens if i use the boost controller and put my boost back down to the stock 7 psi... for daily driving
will i be running rich ? and not as good as say if i already had a stock car will all the fuel maps and etc..be off ?
Adjustable Exhaust Pulley is worth a couple of kw's, some gain and some loose if you do a few searches. From my personal experience, i found a few kw's. Cost approx $200 plus fitting.
If you keep the 12psi tune, then yes the tune will not be 100% correct with 7psi boost. But in my opinion, i doubt whether this would warrant another tune.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
