  • Replies 133
Yeah I'm thinking of putting a new computer in it coz it's not street friendly at this stage. With aircon it always stalls and makes me look like a bad driver so I think i will have to fix that.
I'm not sure if I will be taking it to Steve as yet. Just trying to work out what is the best option at this stage then get some money together first.
Will you be cruising on Friday night with the rest of us?
Originally posted by HUSTLR
LOL:lol: :lol:
doh!!!
Marvin- i heard your putting a new computer in it
Can't make it Friday night-
I was hoping people would turn up on saturday night also
Steve's working on Jap cars like there's no tommorrow lol:lol:
His got 2 import dealers sending there cars to him- plus i'm telling my friends- His always too busy!!!!
You guys are a crack up! :lol:
So you are cruising on Sat then?
If Steve is around Sat day or evening I might come around and see him. Yeah he has alot on his plate ;)
He wants to do a crazy setup for my car- Convert to a twin-turbo - T76- 3L bottom end blah blah blah blah lol:lol: :lol:
Minh - doesn't believe me that he worked on DR CRX's engine setup when he first came out- lol:lol:
Saturday night we hang out at Burger King, corner Cabra Rd and Cumb. Hwy after 10pm and decide where to go runz or cruize-
so what did you do? Who wa sthere?
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
