ok, I painted my ute arcylic and switched to 2pak. 2pak is better looking and was easier to apply. The reason i swapped to 2pak was because i forgot to paint he corners first. remember when you buff / sand the corners will get more wear. and if your doing your 1st wet coat and then buff, with the 2nd jsut do the corners and start again. The clear was easy, just you need to make sure theres no dust around or wind. Or that dead cat...
