Ages ago i was cleaning my R33 GTS-t and under both front seatrs found an electrical connection. Do all 33's have this??
I could only come to the conclusion its for power seats but ive NEVER seen a R33 with power adjusable seats but then maybe i havet looked close enough.
Any help id much appreciat????
https://www.sau.com.au/forums/topic/53324-whats-under-your-seat/
Yepp, seat belt warning light on the dash. But seems as the factory seat belts are replaced when compliance is done, they no longer work.
So just tuck the plug under the carpet.
J
P.S. - I found a japanese lollie still in it's wrapper under my seat. Looked OK to eat, but didn't want to risk it :D
Not sure if its the same for 33's, but my 32 has a plug under the seats also.
It use to plug into the seat belt clipper thingo to say you have your seatbelt on. When my car got complianced it got replaced with some cheap ass DOT approved clippers that dont have this option and now my seatbelt light stays on, but only for 5 seconds or so once the car is started.
Shaun
LOL bong and blueberry.
FYI that blueberry series of gum rocks. If you ever have a chance to purchase muscat, blueberry and the other gums in that series get them. They don't last long but mighty tasty.
When cleaning my stuff (door trims, carpets, seats etc) I found a 100, a 50, and a 1 yen peice as well as a really nice screwdriver, some needlenose pliers, gum, used tissues (eww), some random unidentified peices of something and a helluva lotta zip ties.. haha
haha...i found a blueberry gum stick in my door sil.....didnt want to risk it either.  mmmm.....blueberry:D:D
HAHA how did you know it was blueberry
I'm not looking under my seat, it a never go there part of the car.
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
