Ok car is getting tuned soon, see who can get closest to the mark.
Mods
TD06-20G
45mm External Gate
K&N Air Filter
Q45 100mm AFM
Apexi Power FC
3.5" Custom Exhaust
Nismo GMAX twin plate Clutch
550cc Sard Injectors
Customised plenum
Frount Mount (due to custoised plenum cooler piping is shortnd)
Sard Fuel Pressure Reg
Standard Pistons, cams ect
Im Hopeing around the 280 RWKW, but the guys at the GGG (check signature) rekon ill easy pass the 300 mark,
what u guys / girls rekon.
Post what ui rekon and why if you could and what times i might be able to get down the 1/4
Craig
No the question is how many rwkw do you want?
I can play around with the figures untill it reads as high as you like.
IE: Dyno figures don't mean shit, use it as a tunning tool only. When you attend a dyno day, with other cars to compare against, then you get a slight indication of how good the set-up is.
Probably 275-285 rwkw becuase they'll keep it on the safe side, but its probably possible to see 300 with this setup if I tuned it of course.. :bananaman :bananaman
j/k
I stopped with my setup @ 355rwkw with 21psi screaming all the way to the redline heaps more in it but rod/bolts are still standard.oh by the way thats BP ultimate nothing special at all, Nice 26deg timing, for all you non believers out there... Ill post a dyno sheet if you want I had captain chassis man on before you all start going OH it would have been pinging err you cant get that sort of power... blah blah.
GT3540
45mm Tial gate
standard motor
plenum
fromt mount
EMS Stinger
Sorry im in a stupid mood.
JH
RB25.
i dont care how much i make so long as its reliable.
will post when i get it tuned
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
