  • 3 months later...
Probably 275-285 rwkw becuase they'll keep it on the safe side, but its probably possible to see 300 with this setup if I tuned it of course.. :bananaman  :bananaman
j/k
I stopped with my setup @ 355rwkw with 21psi screaming all the way to the redline heaps more in it but rod/bolts are still standard.oh by the way thats BP ultimate nothing special at all, Nice 26deg timing, for all you non believers out there... Ill post a dyno sheet if you want I had captain chassis man on before you all start going OH it would have been pinging err you cant get that sort of power... blah blah.
GT3540
45mm Tial gate
standard motor
plenum
fromt mount
EMS Stinger
Sorry im in a stupid mood.
JH
I would like to see your dyno. Not that I dont believe you I would just like to see how a 3540 responds on a standard motor. For future reference. I am currently running a HKS 2835.
If your tuner is smart then he will not let it go past 250kw on standard internals, when you see cars running 320 blah blah kw on standard internals they dont run it all the time at that power...
I know of a few std RB25s that have done track days, numerous 1/4 mile passes and plenty of kms on what was std motors with well over 250rwkws...surely the condition of the engine, the manner/purpose in which it is driven and the state of the tune plays a huge part. ?
If the thing isnt needing to run more then 17psi and doesnt require big revs to make over 250rwkws, then i see no reason with a safe tune the car wont be reliable?!?!?!?!?
;)...says the bloke wit the $600 engine...go the RB20:thumbsup:
    • No need to replace the cover if it is still intact (not worn through). It would be worth checking the balancer for matching marks on the rear, but I'd assume the balancer was loose at some stage. The cam timing marks look fine, once you put the new belt on you can only be right or a full tooth out
    • Disconnecting rods! must have been an unpleasant surprise...
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
