WEll i just put a set of new ngk spark plugs and a greddy manual boostcontroller on a mates r33 and the car runs fine until u nail it. 1st gear goes well, i only set it to 10psi to steer clear of complications, but once it shifts into 2nd there is a flat spot until it gets to 6000rpm then it goes well and same in 3rd gear. It feels like the car is hesitating but power iis still rather progressive but just not pulling till 6000. Any ideas?Oh and the car is dead stock besides a can back system.
https://www.sau.com.au/forums/topic/53361-flatspot-on-r33-gtst-auto/
the auto changes gear at 6500 rpm.
We think it may be the auto computer causing the flat spot too. I have disconnected the factory boost solenoid and connected my boost controller do u think that would have an effect? My r33 doesnt have a factory solenoid inplace and just had my boost controller so i did think there would be a drama. any thoughts?
Make sure your speedo wire isn't cut which removes the 180 km/h speed limiter. I had the wire #53 cut and i kept ketting flatspots towards the end of 2nd and 3rd gear.
If unsure the easiest way to check it is try to hit 200 km/h as some speedos are not 100% correct and it might show you 180 km/h + when doing 170 km/h or so.
Oh yeah make sure you do it on a private road or the track :innocent:
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
