Your so right, who gives a rats arse if its fair or not, just do as you are told, good boy - appathetic attitudes really piss me off - maybe you should become a cop, you seem to think that they are right regardless.
Fact - the SA POL DO NOT ENFORCE THE LAW, WITH REGARDS TO THE ROAD TRAFFIC ACT CORRECTLY,
Fact - TPT SA DO NOT ENFORCE VEHICLE STANDARDS CORRECTLY.
I have had enough of these forums
Take care all.
All the Road Traffic Act and Road Traffic Regulations say with regard to ride height is it has to meet ADRs and have a minimum 100mm clearance. How is that wrong or harsh?
  • Replies 50
Take care all.
OOOOK......................
Hey, this is reality and they are the RULES and regulations that govern this state. If you dont like it, do your little bid to fight their bullshit like you attempted to last time. Me personally, Ill do my best to keep my cars 'looking' legal. And the one that doesnt, ill just play the game of staying away. There are more serious matters in life to be whinging about defects on an obviously defective car. By the way, how did your little fight against TSA end up again????? :talk2hand
Then there's the 1/3 of suspension travel, then there's the minimum height your headlights must sit... If they don't get you on one thing they will get you on another *when they want to*.
Adam,
I actually hav'nt looked at the reg's for sa. however i do know that a 100mm block is passed under your car at a regency pk inspection and cannot foul anthing under your car-eg:exhaust, handbrake cables, electrical cables or suspension components etc..
Regards,
SKYLINE(Kym).....
Adam,
      Regards,
                  SKYLINE(Kym).....
When did I say it wasn't 100mm? I've said it is twice! It can foul under the car on a few things though
Ground clearance
 73. (1) In this rule:
"ground clearance", of a vehicle, means the minimum distance to the ground from a point on the underside of the vehicle, except a point on a tyre, wheel, wheel hub, brake backing plate or flexible mudguard or mudflap of the vehicle.
 (2) A motor vehicle or combination must have a ground clearance of:
(a)at least 100 millimetres at any point within 1 metre of an axle; and
(b)at least one‑thirtieth of the distance between the centres of adjacent axles at the midpoint between them; and
©at any other point—at least the distance that allows the vehicle or combination to pass over a peak in the road with a gradient on either side of 1:15, if the wheels of 1 axle of the vehicle or combination are on the slope on one side of the peak and the wheels of the next axle are on the slope on the other side.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
    • For most rotisseries, as Duncan has mentioned, you really don't want a full car on it, you want a stripped shell. And imagine how many more weeks THAT is going to add to working on the car...
