Let's have a conversation in Japanese! (Romaji only)
  • Replies 105
tabun tas no biru wa asahi ka, kirin ka. kirin no biru dai suki da..
Hahaha! Chigauyo! :D
"Bi-ru" ja nakute, tatemono no "biru" desuyo...
chopobo: Makuhari Messe no biru wa JR no Makuhari eki no ichiban chikai no Tenjikaijyou desu. Mecha ooki tenjikaijyou desuyo ne... mitsukariyasui, zettai wakaruyo!
rezz san, doshita orijinaru no kiyarakuta ga batsu man? wakaranai sore no ime wa.
Robaaaaaaaato kun (hehe, like that one), Batsu man wa ore no eikaiwa no "masukotto" (mascot) mitai desu... sanshuukan mae ni totsuzen Batsu man no design o kangaeta.
batsu ha "X" no koto deshou.. demo batsuman ga eikaiwa no jyugyou ni dette nani wo suru no? kare ga dette noba (NOVA) no usagi wo koroseba ii to omou kedo... onegai shite ii no ka ne?? tanomu yo batsuman..
minna, oshougatsu no yotei toka wa nanka nai? boku wa australia ni kaerou kanaa... to omotteru kedo... nihon no oshougatsu wa jissatsu wo shitakunaru gurai tsumaranai to omou.. hatarakanakya dashi naa..
Hahahaha! Boku mo ii to omou!!
NOVA usagi ga mecha mukatsuku ya na... zenzen omoshirokunai ne.
batsu wa X dayo. machigatteiru toki ni deru yatsu.. demo batsu man ga jyugyou ni deru toki ni coffee break wo toru dake dattara deru hitsuyo nai n ja nai desuka? sekkaku detteiru kara oshierou yo! tte kanji ja nai? kare ha nanigo shaberen no? kokuseki wa?
Un, ja nai desu... demo "Ko-hi bure-ku" no "eria-" (area) ni iku hitsuyo ga aru yo...
Sekkaku? Hahahaha! Mmmmm, Sore wa Batsu Man ni yoku niau to omou!
Batsu Man ga eigo shaberaremasuyo... kokuseki wa Nihon jin desukedo nihongo shaberarenai desu... naze ka wo wakarimasen.
kaigai umare???
Kaigai ni umare dattara, nihon no PASSPORT wo eru koto ga dekimasen yo! Demo Batsu Man ga Nihon jin desu. Mada nazeka wo wakaranai...
Batsu man ni tsuite takusan kyoumi ga aru ne... yumei ni nattekiteiru!!!
boku wa cameron desu,
Rezz Dokonisundaemuska ? -(not to sure on spelling or sylibiles.)
Rezz, Ichi ban ski na sportsu wa ? (again not sure on spelling)
Cameron san hajimemashite, yoroshiku onegaishimasu :P
Ima Hyogo ken no Ashiya ni sundeimasu yo.
Supo-tsu no hou dewa sakkaa (soccer) ga ichban suki desu.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
