Go stainless
Hi Tech mufflers have systems available - there was actually a group buy on exhaust for R33 GTS-T's from them a long time ago
9332 3525 - Ask for Lambros and say Nick from Skylines Australia sent you
I had an exhaust made a LE and have no problems. Good work done there. I hear good things about Hi-tech too, but have never had work done there. Hi-tech are in the city, not sure what the suburb is, near darlinghurst.
Richard
yes yes..
I understand.
It's was simply stating that by getting a mild steel one, you will make the same power as a Stainless one.. AND save about $500 which you could spend on other things..
and I was also recommending Western mufflers as I have had 2 of my cars done there for great prices and good work.
that is all.
mate i go to L E all the time and have had many cars through there ask to speak to jimmy and say that ben with the manual v8 soarer sent you and he said he reackons that you could do a little better.
i got a new mini done last week he will remenber that one .
as for hi tec i think there a bunch of dodgy blokes. always taking crap and they charge heaps. eg the mini i took to LE it had a hi tec zorst and was ment to be all mandrel when i had a look the center bends were press bent.
as i said talk to jimmy.
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
