apparently they have allocated points associated with certain mods eg. 50 points for a/m zorst, 100 points for a/m rims and sh1t like that...not sure wat the maximum number of points allowable is tho...heh....who cares
im also 25yo and with suncorp and have a gtst r32...i think u did get a mong tard :P
Hrmm.. my previous insurance was.. Just Cars.. R34 Gtt, with minor mods 1515 for a year. Tho I was listed as Rating 1 with no previous accident history and no fines, blah blah blah. So I was pretty happy at the time :cheers:
Another company you can try is http://www.vigilins.com.au/ I'm not sure how good they are as I only found out about them recently. So no harm for you to try if you havent already done so. :D
Whats the best insurance people have found?
i had suncorp lined up about 9 mths ago they said i had to wait untill i was 25 and then they would insure me for a turbo import (skyline Gts-t 33) for $1000 bargin!!
now im about to get the car i ring up to make sure they will do it and the tell me sorry we only insure the r33 GT, GTS and GTR,  no gts-t, WTF!!!! :werd:  AND they tell me the skyline GTR is a non turbo!!
I asured them that the GTR is Twin Turbo so why cant they insure a single turbo
Wanker at Suncorp: "Sorry i can only insure whats on my screen and the Gts-t is not there"
So i have called just cars and they want $1200 and no pay by the month
Anyone have better insurance company?
Hey,
i've got a 93 gts t, 92 sourer insurered with shannons insurance for well under a 1000 bucks. around 600. mide u ive had another car with them for about 5 years and i'm 29 but over the years they've been really good. Shannons insure people over 25 with everything from hot rods, street machines, vintage, show cars, race cars. u name it
worth a look
Well I had been following this thread for a bit and thought I could not afford full comp, silly me.
I was with just cars for full comp but couldnt afford it this year so dropped back to fire and theft, now in the past couple days saw this thread and started actually calling up places and getting quotes, this and read that the theft is only covered up to and including $5000 with just cars, WTF!?!?!?
Anyway now happily with Suncorp, pay by the month, market value for damage and theft, although i didnt go the $300 more for the windscreen and car hire thing.
Thanks people! :D
  • 3 weeks later...
So i ring suncorp back 4 more times and they still tell me sorry we will insure your for a Skyline GT, GTS and a GTR but no GTS-T
Im just about to go looking for a skyline anytime now and im pretty pissed off that they wont insure me ( refer to the first thread )
I thought i'll try 1 more time and im not hanging up till they insure me! ( as lot of you guys said you have insurance with suncorp)
Just got of the phone 15mins ago with a quote number and 2 Authorisations from the guy on the phone and his boss to insure a skyline GTS-T with a few mods for a touch over $1000 ($1058) and its pay by the month :headspin:
Thanks too ya all for the info and the help :)
    • It's definitely not firing order. But I think it should also be made clear that the output that gets fired is the one that corresponds to the input that was switched at the ECU. So you could scramble them up totally so that the numbers meant nothing, and so long as you had the inputs and outputs matched up, you'd be fine. The reason I make that point is that blanket statements about what it is supposed to be don't always hold out in a world where there's been 30 years for the wiring to have been stuffed with.
    • Hello, im asking about this guy - coil igniter on rb25det series 1 r33 s1 engine. I need to know if pins on coil side indicate coils itself from 1-6 or it’s firing order so pin nr1 goes to 1st fired spark plug:(1pin-1firing spark, 2pin-5order firing spark, 3-3, 4-6, 5-2, 6-4…)   photo: https://files.fm/f/k9pdug38uq
    • Remove it. Certainly from the hub face. I'm not in love with leaving it on the wheel assembly surface either - but if it is common to do so, then....maybe fair enough. It's not difficult. Just time consuming. For the hub face you just need a large enough block and suitable grades of abrasive paper to get it off flat. The same would be true of the assembly face. Just more time consuming, probably needing a lot more care. It's defo going to be easier just to assemble the wheels as is, seal them up, and check them periodically to see if there's any movement or loosening of the fasteners, than it will be to remove it though.
    • Hello, I got my wheels powder coated and they've powder coated bloody everything the mating surface and hub (even told them not to lol) anyway should I leave it or remove it. (Would be very hard) I've searched a lot and lots of powder coaters don't mask the mating surface but do mask the hub surface. How bad it powder coat on the mating surface or hub? My question is what should I do?
    • Yeah, R34 with RB25DE likely has a 4AX01 box in it, which is a medium duty auto ~ with the RB25DET mill, it would've been fitted with 4AX00 (4AX13) heavy duty build (same case, different internals). An RB25DET will lunch on a medium duty 4R01 auto in pretty short order ...to give you some visual idea of differences between the 'medium' and 'heavy duty' boxes, you only have to look at the 2/4 band for comparison...it's chalk and cheese...(plus bigger high clutch, extra pinion in the planetary sets, higher oil pump output, different bearings, higher TC stall speed )... You can control them with just about any aftermarket TCU for electric-over 4-speed with TC lockup clutch (ie; the GM 4L60E and others)...I have a custom standalone TCU that includes MAP sensor (for turbo applications) along with TPS, RPM, and line pressure monitoring...in other words, I don't use any ECU signals...no real need to.
