Hi guys,
I notice that when I start up my car or turn off the ignition, I can smell petrol. The smell is on the outside of the car and comming from the front.  Is this normal or do i really need to get this checked out? Does any one know why I can smell petrol?
thanks
kim
has it just been complied??
https://www.sau.com.au/forums/topic/53430-petrol-smell/#findComment-1048949
  • 4 weeks later...
I had a fuel smell recently, I thought it came from the front as well. when you start your car look in your drivers side view mirror and see if you can see fuel fumes coming from the petrol filler door. if you can you need to pull out the little flapper plate and reseal it with a petrol tank repair putty.
It's easy to do just make sure you disconnect the tank pipe under your guard and you can remove the whole filler insert. and go from there. if you have any other questions let me know.
https://www.sau.com.au/forums/topic/53430-petrol-smell/#findComment-1079257
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
