Hi guys,
I notice that when I start up my car or turn off the ignition, I can smell petrol. The smell is on the outside of the car and comming from the front.  Is this normal or do i really need to get this checked out? Does any one know why I can smell petrol?
thanks
kim
has it just been complied??
https://www.sau.com.au/forums/topic/53430-petrol-smell/#findComment-1048949
  • 4 weeks later...
I had a fuel smell recently, I thought it came from the front as well. when you start your car look in your drivers side view mirror and see if you can see fuel fumes coming from the petrol filler door. if you can you need to pull out the little flapper plate and reseal it with a petrol tank repair putty.
It's easy to do just make sure you disconnect the tank pipe under your guard and you can remove the whole filler insert. and go from there. if you have any other questions let me know.
https://www.sau.com.au/forums/topic/53430-petrol-smell/#findComment-1079257
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
